ccotenj finally gets a projector... :) - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 05-22-2012, 04:38 PM - Thread Starter
ccotenj's Avatar
Liked: 101
so the onerous task of spray painting the radiator is finally done... that is a MAJOR item checked off my "irritation list"...
the next thing was the wires in the front... as noted earlier in this thread, i do not like to see wires... decided the best way to hide them was to build a soffit along the floor in the front of the room to run everything through...
started with a high quality, made in america snake... 3 runs of monoprice in-wall 12 gauge, a rca pair for the subs, and the cable for the fios and the network cable jump in halfway...
if it's gonna be a snake, might as well make it look like a snake...
ran it to front of room and terminated in middle of front wall...
turned the outlet into a j-box...
soffit in place... speakon connector for center channel...
speakon for one speaker, pass-thru sub connection and locking outlet for one sub...
- chris
ccotenj is offline
Old 05-22-2012, 04:41 PM - Thread Starter
ccotenj's Avatar
Liked: 101
prepped for painting...
my buddy rich hard at work...
other side...
- chris
ccotenj is offline
Old 05-22-2012, 04:44 PM - Thread Starter
ccotenj's Avatar
Liked: 101
no more wires in front! yay!
however, part 2 is still a pile... hopefully i'll get something done with this mess soon...
and we need to do something about properly running the pj wires...
- chris
ccotenj is offline
Old 05-22-2012, 04:50 PM - Thread Starter
ccotenj's Avatar
Liked: 101
still needed to spruce things up a bit, so more high quality made in america cabling...
cat proof power cords for subs... neutrik powercons on one end, locking plugs on the other... little sucker ain't pulling these out... and hopefully can't chew through the techflex, although i'm not putting it past him....
couple of speaker cables.... neutrik speakons on one end, gls bananas on the other...
- chris
ccotenj is offline
ccotenj's Avatar
Liked: 101
so, part 1 of "hide the wires and make chris happy" is done.... hopefully more to come shortly...
- chris
ccotenj is offline
Old 05-22-2012, 05:41 PM
m. zillch's Avatar
Quoted: 1827 Post(s)
Liked: 1172
You've been busy!
What's with the 4 to 5 foot drop extension pole from the ceiling to the pj? Can't it be flipped upside down and mounted just a foot or so from the ceiling, shooting downward?
I must be missing something.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
Old 05-22-2012, 07:18 PM - Thread Starter
ccotenj's Avatar
Liked: 101
yup... keeps me out of trouble...
yup, it's actually upside down already (4 foot drop pole, just a threaded steel pipe that i sprayed black, mounted to a plumbing flange)... that's a da-lite hphc screen... being retro-reflective, it "wants" the projector mounted as close to eye level as possible... thus the long drop... it was on that shelf there before, but getting it on the pole (and the rack out from behind the couch) gives me a bit more floor space to work with...
i gave it my usual "strength test" (grabbed onto it and held myself in the air) before sticking the pj on it to make sure it would hold...
- chris
ccotenj is offline
Old 05-22-2012, 07:33 PM
m. zillch's Avatar
Liked: 1172
Originally Posted by ccotenj View Post
retro-reflective
Got it!
Old 05-22-2012, 08:12 PM - Thread Starter
ccotenj's Avatar
Liked: 101
yea, i figured you missed the part where i sold the black diamond and got the da-lite... damn, i took a beating on that... but it was worth it in the end...
- chris
ccotenj is offline
Old 05-22-2012, 09:42 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
PLEASE tell me you weren't surrounded by a crowd showering you with dollar bills
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
Old 05-23-2012, 06:13 AM - Thread Starter
ccotenj's Avatar
Liked: 101
hey, i have to fund this project somehow...
- chris
ccotenj is offline
Old 05-23-2012, 10:15 AM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
Interesting that the type of screen can influence where your PJ should live. I'm at the pre-planning stage of adding a PJ and screen so I have quite a bit to learn. I'd like to do it "budget-style" as I've been hemorrhaging funds lately on this damn hobby .
Old 05-23-2012, 01:47 PM - Thread Starter
ccotenj's Avatar
Liked: 101
i hear that...
basically, you have angular reflective screens (almost all of them) and retro-reflective screens (just a few)....
the names pretty much describe what they do... retro-reflective screens reflect the light back to where it came... so the closer you are to the lens of the projector, the more "light" you get (i.e. the brighter the picture is)...
whereas an angular reflective screen reflects light at the opposite angle of which it came in... ideally the lens would be positioned the same distance above the centerline of the screen as your eyes are below it...
depending on your circumstance, one can be "better" than the other... the da-lite retro screens give you a ton of gain IF you are sitting within the viewing cone, and being retro, are a bit better in ambient light (from the sides/ceiling anyway).... the viewing cones tend to be rather narrow though, and the gain drops rather quickly once you get close to the edge of the cone....
i'm ready and waiting to design your room for you...
- chris
ccotenj is offline
Old 07-07-2012, 06:24 AM - Thread Starter
ccotenj's Avatar
Liked: 101
pic test...
450
- chris
ccotenj is offline
Old 07-07-2012, 08:05 AM - Thread Starter
ccotenj's Avatar
Liked: 101
cool, we have pictures again... smile.gif if anyone comes across a broken link i missed, let me know... i think i fixed them all; it was rather fun to relive the last 14 months... smile.gif
if it ever gets below 95 here in the toxic waste dumps, the next phase of the "hide the wires" project will be complete... smile.gif only thing i have left to do is paint, and that's not happening until it cools off enough to open the windows...
- chris
ccotenj is offline
Old 07-07-2012, 10:58 AM
m. zillch's Avatar
Liked: 1172
^The cat's are saying: "Ah, finally, 6500 degrees Kelvin across the board! This is like tuna!"
Old 07-07-2012, 01:28 PM - Thread Starter
ccotenj's Avatar
Liked: 101
- chris
ccotenj is offline
Old 07-07-2012, 03:40 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
Old 07-10-2012, 05:43 PM - Thread Starter
ccotenj's Avatar
Liked: 101
no link?
but of course i sing to them... and talk to them... smile.gif i can call the little black evil beast the worst names in the book, but as long as i say it in a nice voice, he still thinks i'm telling him he's wonderful... no cat has led a more pampered or spoiled life than he has... and he is STILL evil... smile.gif
the only thing that saves him from a one way trip to the shelter is that i'm the king of his world... smile.gif in that way, he's kind of like a dog... when he hears my car pull into the driveway, he runs and jumps up in the window and meows... lol...
- chris
ccotenj is offline
Old 07-10-2012, 05:58 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
Weird-link works fine for me. More quirks with the new site I guess. I'm a big animal guy as well, and my dog likes everything HT except the Audyssey chirps smile.gif. Anyway, here's the link again the "old fashioned" way:
http://www.youtube.com/watch?v=cSV3cKkLObM
Old 08-20-2012, 02:57 PM - Thread Starter
ccotenj's Avatar
Liked: 101
"he was talking to the cat... and the cat was talking back..."... tongue.gif
- chris
ccotenj is offline
Old 08-20-2012, 03:09 PM - Thread Starter
ccotenj's Avatar
Liked: 101
my poor old sofa was fixing to fall apart and do serious injury to me, so i finally got theater seats... talked to roman, and they were here in 3 days... i highly recommend him, his service is great and he responds virtually 24 hours a day...
i'm REALLY glad i got these... they are the fusion escapes... very comfortable, and the electric headrests alone are worth the price of admission... taken as whole, they were relatively inexpensive (625 each) compared to "regular furniture", considering the toys that come with them...
pics...
- chris
ccotenj is offline
Old 08-20-2012, 03:17 PM - Thread Starter
ccotenj's Avatar
Liked: 101
after i made myself safe from attacking furniture, i then FINALLY solved my projector shaking issue... whether i mounted it to the ceiling, wall or shelf, i could not stop it from shaking... it's an old house (1903), and even "heavy steps" were causing shaking, let alone what happened when the subm fires...
after kicking around a lot of different ideas, i came up with the idea to build an isolation pad with sorbothane feet...
the feet...
took an old 1" thick piece of cherry i had lying around from an old stand i had built and painted it black (of course)...
drilled holes in the corners...
installed the feet...
on floor in back of room...
repurposed a lingerie chest to use as a stand and storage area...
- chris
ccotenj is offline
Old 08-20-2012, 03:20 PM - Thread Starter
ccotenj's Avatar
Liked: 101
and virtually no more shake... smile.gif i may yet build a small platform for the pj itself on top of the chest to eliminate the last of it....
if you do use this solution, it is VERY important to get the weight right... i had to stuff a couple bricks in one of the bottom drawers in order to get enough mass for the sorbothane to get into it's "happy zone"...
now, of course, the "home theater - the second revision" project has started... redface.gif need to stash some cash for that though...
- chris
ccotenj is offline
Old 08-20-2012, 04:16 PM
m. zillch's Avatar
Liked: 1172
Glad it all seems to be working out, but I thought to add something if there were still issues: In addition to the pj shaking from sub rumble, you also need to be sure it isn't the screen vibrating that's causing visual anomolies. [Or YOU for that matter. smile.gif ]
Old 08-20-2012, 04:22 PM - Thread Starter
ccotenj's Avatar
Liked: 101
yea, the screen (and i, ftm) are still going to move when the sub fires hard... i can deal with that (since i'm not sure how to stop the screen itself from moving)...
it's at a "more than acceptable" spot in terms of that right now... at least until i get my front porch remodeling done (hopefully within the next 2 weeks, i am SO tired of sanding)... they i may play a bit more....
like i said, i'm gonna redo the whole shebang to see how close i can get to a "dedicated" room... i'll never have a true home theater in here (i have zero chance of soundproofing this room), but i want to get as close as possible... the minimalist in me is winning the battle at this point...
especially since i got the HDbaseT solution up and running... i was able to get a majority of the equipment out of the room and in the rack in my wife's kingdom... win/win... i don't have to look at it, and she likes looking at all that stuff... smile.gif
- chris
ccotenj is offline
Old 09-14-2012, 08:27 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Chris - The room is really coming together and looks great. It's a shame you can't make it out to our GTG as I'd love to get your feedback and suggestions on my room. Heck, you're close enough so maybe another time. tongue.gif
Andrew
Gorilla83 is offline
Old 09-14-2012, 09:18 AM - Thread Starter
ccotenj's Avatar
Liked: 101
sure, that'd be fun... we'll set something up once october is over... i'd like to see/hear your setup...
- chris
ccotenj is offline
Old 11-03-2012, 07:54 PM
Glimmerman911's Avatar
Liked: 32
I have the same fusion seats from Roman, I am still loving mine, other than it would have been nice to have a switch to turn off the blue and red LED lights.
18.5ft x 14ft home theatre room with 120" screen and 7.1 sound
Glimmerman911 is offline
Old 11-14-2012, 09:50 PM
audioguy's Avatar
Quoted: 1916 Post(s)
Liked: 1240
You must have either lived in the south or your parents did or you have some other southern connection. I have lived and traveled all over the US and the ONLY place I have ever heard the expression "fixin' to" has been in the south.
I like your new chairs !!
audioguy is offline
