Screen obstruction - AVS Forum | Home Theater Discussions And Reviews
Old 10-08-2011, 01:02 PM - Thread Starter
khoelle's Avatar
I have never owned a projector before will be buying a 8350 in the coming weeks.
But my question is about screen placement. My basement is only 7ft. 3ft from the wall I have a support beam that is 6in. I will have my projector ~12ft from screen no more than 1ft hanging..(im 6'2" so dont want to bump head).. But what I am wondering is if that beam will be in the way with the top of the screen 1ft down from the ceiling. Or if the beam(painted flat white...) will cause bad reflection.
I can move where I will have the setup, but this is the best location for all my components and such.
khoelle is offline
Old 10-08-2011, 04:16 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 915
Can you draw it out (to scale) on graph paper on in a designing app? That should show you.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
Old 10-08-2011, 05:50 PM
Quoted: 3308 Post(s)
Liked: 2797
Just take a flashlight and hold it where you plan on mounting the projector. Aim it at where you are thinking of hanging the screen. Move it up and down, and it should be obvious how high you can hang the screen.
It would help your theater set up to paint ceiling and walls a darker color.
Old 10-09-2011, 02:09 PM - Thread Starter
khoelle's Avatar
Im not sure how a projector is projected. like a flash light im sure isnt as focused as a projector is. the lens of the projector based on the numbers ive gotten will be a good 4-6in below the beam. I just really have no idea
khoelle is offline
