Anybody have examples of covering an entryway without a door? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-03-2012, 11:19 AM - Thread Starter
gundam83's Avatar
I have a 40" entryway into my living room. Aside from that, the room is completely enclosed. I have blackout curtains on the two windows inside the room, but I'm still getting some ambient light from the entryway. Here is what I have to work with:
gundam83 is offline
post #2 of 4 Old 01-03-2012, 02:12 PM
s002wjh's Avatar
Quoted: 33 Post(s)
maybe some heavy cloth/cotton/bead on string door drape. heavy density drape is also good for blocking/damping sound
s002wjh is offline
post #3 of 4 Old 01-03-2012, 09:10 PM
peteypistol's Avatar
Do you prefer to hang something instead of installing a door because you dont want a door taking up that space? If so, a pocket door would work well
peteypistol is offline
post #4 of 4 Old 01-04-2012, 10:27 AM - Thread Starter
gundam83's Avatar
Pocket door would be ideal, but I don't have the skills to put one in, and I would imagine it would cost quite a bit as well. Unless it's only about $2-300 for a pocket door, I will have to settle with some sort of drapery
gundam83 is offline
