Newbie seeking HT Advice - Definitive Pro 600 with Pioneer VSX 53 - AVS Forum | Home Theater Discussions And Reviews
Old 01-04-2012, 01:38 PM - Thread Starter
911fan's Avatar
Hello,
Complete newbie and looking to upgrade from a Bose 321 System (time to "man up") to a true Home Theater system. Looking to pair a Pioneer VSX 53 Receiver with Definitive Pro 600 Speaker System.
Room size is 14 ft W x 12 ft L
HT Uses - Gaming 30%, Movies 30%, Music 20%, TV 20%
Budget - looking to stay in the $1500 - $2000 range for speakers + receiver
Be keen to get your thoughts and opinions on this set up and if you have an alternate setups I should consider.
Thanks in advance for your help.
Cheers - 911fan
911fan is offline
Old 01-05-2012, 09:20 AM
tomdahlberg's Avatar
You should probably check with the AVR and Speaker sub-forums with these questions.
tomdahlberg is offline
Old 01-05-2012, 09:41 AM - Thread Starter
911fan's Avatar
Thank you. Brand new to the avs forum so wasn't sure where to post and quickly realized this was more design/construction related forum. Re posted to speaker sub forum.
911fan is offline
