HDMI 2 way splitter? 2 displays 1 PS3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-04-2012, 04:31 PM - Thread Starter
bfal's Avatar
Hi,
New to this forum, but have been into AV for quite some time.. I am contemplating the idea of having my ps3 connected to both my TV display and computer display.. I have read that gaming is better on a smaller display and would like to give it at shot. However, I don't want to lose the ability to use my PS3 on my tv as well..
I have a LG PK950 plasma TV. Computer monitor is a Samsung P2350. Right now my ps3 is connected via HDMI. My pc monitor only has DVI inputs. The nice part is my PC monitor is only 4 feet from my TV, so short cables are all I would need.
I guess my main concern in this is loss of picture quality on either display. I really am not willing to sacrifice PQ at all.
What would your thoughts or recommendations be as far as splitters be? Any other issues I should be aware of?
Thanks in advance!
B
bfal is offline
post #2 of 3 Old 01-04-2012, 07:58 PM
airscapes's Avatar
Quoted: 354 Post(s)
Liked: 285
Originally Posted by bfal View Post
Hi,
Thanks in advance!
B
You want to look at HDMI Matrix Switches. Monoprice.com has a bunch. I got the 4x4 so as to never run out of ports.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 3 Old 01-06-2012, 04:03 PM
SeldomSeen31's Avatar
Quoted: 23 Post(s)
Liked: 35
I use the monoprice splitter to split my ps3 output. Much cheaper than a matrix, but gets the job done for me. One output goes to receiver and then to basement big TV, other goes through the floor to living room TV. Bluetooth controller works just fine.
HDMI will give the lowest common denominator when output to 2 devices, so if your monitor is not 1080P for example then if running both TV and Monitor at the same time, your TV will only display the max rez of your monitor.
I use HDMI in on the devices that I have used the splitter with so have not experience with adding an HDMI to DVI adapter in to equation which could change how it all works out. HDMI can be a finicky thing as is noted all over these forums.
PSN ID: Seldom_Seen
SeldomSeen31 is offline
