Max viewing distance of 9ft, projector for me? - AVS Forum | Home Theater Discussions And Reviews
Old 01-08-2012, 05:31 PM - Thread Starter
bmfjimbo80's Avatar
I have always wanted to do a big 90" + screen with a projector setup. I'm refinishing the basement now that i have added the new room and now going to install a home theater system. Here are my two options as far as setting up the tv area. I can either do the room as 12.5ft x 9.5ft with the screen on the 9.5ft wall with the couches against the back wall giving me 12ft but no room to mount the projector behind. Or i can put the wall on the 12.5ft wide wall but then only have max viewing distance of 9ft but could mount the projector back 12 to 14ft. Is a projector setup out for me?
bmfjimbo80 is offline
Old 01-08-2012, 06:31 PM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
You need to use the "throw distance" calculator to see if how big of an image you can get from your choice of projectors at the available distances. Nothing says you have to mount the projector behind the couch, either. That's a preferred location, but not mandatory.
And don't forget that the distance calculations are from the lens of the projector. You have to subtract that from your room distance (meaning - a 12" deep projector in a 14' deep room has a max of 13' throw).
But yes, you've probably got enough room.
Jeff
jautor is offline
