Belkin Power Conditioner/Surge Protector - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 10-04-2013, 10:30 PM
Cravit8's Avatar
Quoted: 1151 Post(s)
Liked: 610
Originally Posted by bronxer View Post
I have 2 Belkin PF60's - one on my HDTV connected to a cable box (downstairs) and one to my upstairs surround sound music system (Yamaha RX V1 and Pioneer Elite DV45A SACD player).
The signal strength to my cable box was never great - I've had repair men at my house numerous times. But since connecting the Belkin my signal strength is great and the color saturation and image clarity had improved.
As for my music system - the sound is slightly fuller - I suffer from tinnitus and didn't use my stereo for over 2 years - My ears would be ringing after listening - but not after buying the Belkin PF60. The sound is awesome.
The reason I bought the Belkin - I went to a friend 's apt a few years ago - he had a high end system with the Belkin power console and he spent $600 on it. So for $200 I figured if give it a try. I'm glad I did.
The Belkin PF60 does none of those things because it doesn't have mystery science magic unicorn dust inside it.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
Old 10-20-2013, 01:13 PM
Answer Seeking / Sharing
cavchameleon's Avatar
Quoted: 194 Post(s)
Liked: 219
Agreed! Open it up and you'll see all the parts clearly (filters/chokes/electronics for switching, etc.). The unit is basically a good surge protector with the ability to remove spikes in electrical current if any. IMO the best part of the PF60 is the ability to control On/Off sequencing of equipment (I don't like all equipment to go on all at once). There is no 'magic' in the unit (does not improve audio or video performance). It does help with surges and protects your equipment if needed but remember that the first and main place to protect against surges is using a whole house surge protector (put in or near the electrical box). The secondary protection surge protectors (such as this and others) are good for surges created within the house.
There are other units out there (very expensive I might note) that actually re-generate your electricity (using large transformers). Those unis do give you very clean power, but whether it is audible (or improves video) I can't say (I couldn't tell). Here is an example of one from Furman:
Just a side note, no surge protector (even whole house types) will protect against direct lightning strikes.
Cravit8 likes this.
Ray
"Listen with an open heart and mind."
cavchameleon is offline
Old 03-03-2014, 09:34 PM
luvthefloyd's Avatar
Has anyone found generic rack mount ears that work with the PF60? I know in the past Belkin used to supply them with the unit but that's no longer the case.
By Grabthar's hammer.......... What a savings.
luvthefloyd is offline
Old 03-03-2014, 09:40 PM
Quoted: 194 Post(s)
Liked: 219
Old 03-03-2014, 10:53 PM
Good ideas, thank you.
Old 03-04-2014, 06:30 AM
Quoted: 194 Post(s)
Liked: 219
You're Welcome!
Ray
Old 03-04-2014, 07:07 PM
Cravit8's Avatar
Liked: 610
Good find.
Something I seem to recall about warranty being voided if rack mounted. That implies there is a danger to the device and they don't want to cover it, therefore sitting on a rack shelf would be prudent.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
Old 03-04-2014, 08:43 PM
Quoted: 194 Post(s)
Liked: 219
Good find.
Agreed, it's the best way to rack-mount most equipment. I've seen equipment chassis/casings warp from being rack mounted with 'ears'.
Ray
Old 09-23-2014, 05:30 PM
Cravit8's Avatar
Liked: 610
Everyone's Belkin PF60 still holding up? Mine has been without fault.
-Crav
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
Old 09-28-2014, 05:41 PM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 279
-Crav
I still have mine plus the battery back up one. I have replaced the batteries twice since 2006 or 2007.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is online now
Old 10-31-2014, 02:38 PM
rfb6435's Avatar
Quoted: 118 Post(s)
Liked: 50
My PF60 is running strong. I have it turning on with a 5V trigger from my AVR.
My unit is the version with trigger delay controls on each outlet.
It has no ethernet connections...
The display also doesn't turn all the way off.
It also has a 110v trigger that could be plugged into an AVR's switched outlet using a basic detachable cord from a laptop power supply, old boombox, etc.
My AVR also doesn't have a trigger out for the main zone so I am currently using the second HDMI output with a custom cable that connects the pwr/gnd from the HDMI port to a 1/8" mono mini plug with +5v on the tip of the mono plug. HDMI is required to supply 5V/55mA (the pf60 accepts a 3v-30v 30mA trigger) so there are no issues there (unless I were to short out the mini plug or something).
I have also used a USB to 1/8" mono cable with my older receiver that had a rear USB connector (which unfortunately the newer AVR doesn't have).
The AVR power outlet is set to always on, the external amplifier is switched on with a delay after the AVR is turned on and sets the trigger as are some of my other accessories.
-Rich
Marantz SR7009 Atmos 9.2.2 or 7.2.6 (scAtmos).
Adcom GFA-7500 150W/ch (WL/L/C/R/WR), Adcom GFA-7607 125W/ch (TMR/SR/SBR/SBL/SL/TML)
HTD L3 Tower L/R/C, HTD L2 Tower WL/WR, HTD Dual 12" Subs
HTD L2 Bookshelf SBL/SBR, HTD 6.5" Angled Ceiling FHL/FHR/SL/SR, HTD 8" Ceiling TML/TMR
Epson 5300ub 1080p 3D Projector with Monoprice 106" Multi-Format Screen.
rfb6435 is offline
