How to wall mount speakers? (it's more than that!) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 02-16-2012, 12:59 PM - Thread Starter
Hercules's Avatar
I have the Klipsch HD300 set of speakers that I just bought, and I want to wall mount them all. I have a few questions though..
First, I'm going to run the wire behind the wall, but do I need in-wall rated speaker wire? Secondly, should I add a binding post, or just take the wire through a hole in the wall and thread it right into the mount?
The goal is to have as little wire showing as possible.. I figured having a binding post would be a good idea just for the sake of a clean looking install, but I'm noticing most installs don't have any binding posts at all. I'm going to have a main binding post for my receiver, but running the wires outwards from that is where I'm left wondering.
If anybody has suggestions for mounts that aren't too expensive and angle downward, that would be great also!
Thanks for any help!
Hercules is offline
post #2 of 16 Old 02-16-2012, 01:43 PM
bluedevilbrent's Avatar
You need in wall rated speaker wire to meet code. That being said, you can do whatever you want in your house but if you go to sell it you might be asked to upgrade it or rip it out. I would do the in-wall right away if you can, it doesn't cost that much more. Obviously get it from Monoprice if you can.
You don't want to be able to see the wire coming straight through a hole in the drywall and I am guessing that it would be against code to have holes in your drywall. Other than that it is personal preference on what you use.
Here is an option that mounts direct to a single gang elec box. Kind of pricy but would give you that clean look.
http://www.crutchfield.com/p_121AM20...=Pinpoint+AM20
bluedevilbrent is offline
post #3 of 16 Old 02-16-2012, 01:48 PM - Thread Starter
Hercules's Avatar
I have no problem with in-wall speaker wire, I just want to know how to use mounts to keep the wire hidden, and what method people use. I am happy to use a LV box for the wires, but then we're talking about adding a wall plate or a mount that goes right onto the box. Not everybody buys a mount like that, so what other options do people use?
Hercules is offline
post #4 of 16 Old 02-16-2012, 02:27 PM
I am not sure I understand what you are asking. Some how you have to connect the wire to your speaker so it will be visible at least a little. Not many speaker mounts do wire management unless they connect to an elec box.
check out this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1191178
post #5 of 16 Old 06-25-2012, 08:34 AM
marsi00's Avatar
I have a question on the same topic . . .
When wall mounting the speakers, is it common to put some type of dampening material (ex: foam) between the mount and the wall to stop any vibration or sound transfer?
marsi00 is offline
post #6 of 16 Old 06-26-2012, 05:20 AM
SmokenAshes's Avatar
Liked: 53
Check out my thread I created awhile ago. Do a search for
First time HT build, The Smoken Theater
I don't know how to link on this stupid app since the official AVS forum app doesn't work anymore.
Sent from my DROID RAZR using Tapatalk 2
SmokenAshes is offline
post #7 of 16 Old 11-29-2012, 05:37 PM
Ed Weinman's Avatar
Quoted: 56 Post(s)
Liked: 36
I, also, have a question that I cannot find an answer to...
I am mounting a speaker to a side wall that needs to extend from the wall out into the tv room and bend, slightly down, aiming it to the listerner position.
All the mounts that do this kind of articulation seem to apply to tv's...can any of them also apply to a small speaker (i.e., the Sunfire CRM-2BIP).
Thanks, in advance, for any suggestions.
Ed Weinman is offline
post #8 of 16 Old 11-29-2012, 08:55 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Sunfire ACC-2WB speaker mount?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #9 of 16 Old 11-29-2012, 09:48 PM
Ed Weinman's Avatar
Quoted: 56 Post(s)
Liked: 36
Neurorad,
Thanks for the reply.
...I guess I didn't explain what I needed...the mount has to have the capability to extend up to 24" from the wall and, then, be able to aim the speaker downward toward the listining position...
...these types of mounts are all over the place to LCD (etc.) tv sets but I cannot find any that apply to speakers...(unless a purchase one and try to modify that portion that usually attaches to the tv set so that it could hold the speaker)...
post #10 of 16 Old 11-30-2012, 03:40 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Sorry, misunderstood.
Care to share more details, about why the speaker needs to move using an articulating mount?
Neurorad is offline
post #11 of 16 Old 11-30-2012, 06:59 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Re 24" around and down mount.. may need to draw something up and visit your local welding shop.. sounds kind of custom..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #12 of 16 Old 11-30-2012, 09:31 AM
Ed Weinman's Avatar
Quoted: 56 Post(s)
Liked: 36
...the room is odd-shaped...the speaker's design requires room from it's sides in order for the sound to project ...if the speaker is just hung on the wall, it would be facing the wrong direction...the speaker needs to come out from the wall aprox. 24", make a 90% turn, then angle down towards the listening position...
Hope this helps some...
Thanks, again
post #13 of 16 Old 11-30-2012, 10:25 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
link to speaker?
Neurorad is offline
post #14 of 16 Old 11-30-2012, 10:32 AM
Ed Weinman's Avatar
Quoted: 56 Post(s)
Liked: 36
link to speaker?
www.sunfire.com
X series
(CRM-2BIP)
post #15 of 16 Old 11-30-2012, 11:10 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Oh, sorry, yeah, you mentioned it already. Looks like it is designed to be mounted ON the wall, and not at a distance. The open spot on the wall, I guess, is flanked by something?
The problem with using an articulating TV mount is the weight issue. You'll need to find a mount designed for that weight, 8 lbs per Sunfire.
Take a look at articulating wall-mount options for monitors, and not TVs/displays, from Chief and Peerless. Looks like they accommodate monitors in the 5-25 lb range.
Those ribbon speakers look pretty slick.
Neurorad is offline
post #16 of 16 Old 11-30-2012, 07:55 PM
Ed Weinman's Avatar
Quoted: 56 Post(s)
Liked: 36
...you know, I've decided to forget the mounts and bought shelf brackets, shelf tracks (etc.) and use these to mount the one speaker which cannot be flush with the wall (there is no problem with the other speaker mounted on the wall).
...I've spent hours (days!) trying to research posibilities and am very, very tired of it all...Neurorad, thanks for your input.
Speaker Systems , Wall Mount
