How would this work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-17-2012, 06:02 AM - Thread Starter
DCVL's Avatar
I plan on using my laptop for a media PC. I want to run the audio/video from my laptops HDMI port to my TV and then have it play through a 5.1 surround sound system (which I have not bought yet)
Is this possible? Will the audio go out through my TV and play through my surround sound? Is it just a matter of going into the TV menu and telling it to output the sound through w/e port it's plugged in to?
DCVL is offline
post #2 of 4 Old 02-17-2012, 07:46 AM
Scout's staff's Avatar
I would think you would connect your PC to your AVR via HDMI and your AVR would then connect to the TV via HDMI (via the AVRs HDMI out) - the picture flows through the AVR.
Scout's staff is offline
post #3 of 4 Old 02-17-2012, 07:52 AM
NickTheGreat's Avatar
Quoted: 424 Post(s)
Liked: 301
Does your TV have optical audio out? This would accomplish what you're asking.
But are you buying a HTIB or a new receiver? You could always run the HDMI into the receiver, and then receiver to the TV
NickTheGreat is offline
post #4 of 4 Old 02-17-2012, 08:05 AM
Sidekicknichola's Avatar
I do exactly this and it works great...
I run HDMI from my PC to the receiver, then another hdmi to a projector, I get full 7.1 sounds + 1080p display from the PC
Sidekicknichola is offline
