Is basement too small for surround sound? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-03-2012, 03:41 PM - Thread Starter
jiggyk4's Avatar
We are getting ready to buy a new house and have fallen in love with a house with a weird basement. It is finished and 11x40x7 ft high ceilings and don't know how good this will work with surround and possibly a projector. I currently have aperion grand towers and matching center and surrounds because I was thinking we would find a bigger basement but hopefully this one will work just wanted to get some opinions thanks
jiggyk4 is offline
post #2 of 10 Old 03-03-2012, 04:23 PM
Dan Hitchman's Avatar
Quoted: 3561 Post(s)
Liked: 1905
It'll be narrow, so you'll have to be careful with how you arrange your seating. If you want a second row, the riser will have to be fairly low... that means the screen will need to sit a bit higher than normal. There's a riser height calculator on the dedicated theater thread.
Due to the lower than normal ceilings, you'll also have to choose a projector that allows for a good deal of vertical lens shift adjustment. That would automatically rule out most DLP projectors, as they mostly have fixed image offsets for 8 foot or higher ceilings. And you'll want a flush mount ceiling bracket.
One thing to consider is a projector with a long throw lens, so you could mount it behind your seating so you don't have to duck.
Another point... since the room is 40' long, you'll want to strongly think about walling off your main theater section from the rest of the basement and keep it dedicated. Otherwise, you'll wish you had different speakers like Seaton, Triad, Procella, or other brands and multiple subwoofers designed for large home theater spaces.
The only other option would be to start looking at different houses with generous, open floor-plan walk-out basements (usually can accommodate 9 foot or higher ceilings) or at least those with below-grade basements with standard 8 foot ceilings (if you're lucky) that could easily handle a home theater environment.
It all depends on how "in to" home theaters and "man caves" you are. Personally, I'd keep looking.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #3 of 10 Old 03-05-2012, 05:13 PM - Thread Starter
jiggyk4's Avatar
Thanks for all the help the ceilings are actually 8 foot and after measuring better the room is actually 11 ft wide. My wife loves the house so im guessing im not gonna have much of say but I think I can make it work I just may not get to have a projector
jiggyk4 is offline
post #4 of 10 Old 03-05-2012, 07:20 PM
g_bartman's Avatar
Quoted: 170 Post(s)
Liked: 139
I'm in a townhouse with a small basement. The main part that my ht is in is 30x15. I have a 7.1 setup that sounds very good. Curious why you dont think you will be able to do a projector.
g_bartman is offline
post #5 of 10 Old 03-06-2012, 10:58 AM
Tedd's Avatar
Quoted: 1151 Post(s)
Liked: 440
Think acoustically transparent screen on one end wall.
A nice example: http://www.avsforum.com/avs-vb/showthread.php?t=1036161
Tedd is offline
post #6 of 10 Old 03-06-2012, 03:23 PM - Thread Starter
jiggyk4's Avatar
I still may do the projector just not sure about the room size that's all but im going back to the house to check it out some more and the acoustical screen in the back will be a must. I am going to see about widening the basement also because I want it to be at least 13 to 15 ft
jiggyk4 is offline
post #7 of 10 Old 03-07-2012, 02:01 PM
Liked: 1905
That's a good example of a clean looking AT screen retrofit in a smallish basement! SeymourAV has a good 4k resolution friendly transparent fabric (perhaps SMX does too)... might as well be ready for 4k projectors if you're just starting with an AT screen.
The only thing I'd do is paint the room a darker color and add more acoustic treatments throughout the space.
post #8 of 10 Old 03-07-2012, 03:04 PM
Tedd's Avatar
Liked: 440
All good points. And I'll add, I'd use less framing.
I have a 54x96" AT screen in what's is 79" below the soffit, and 9'5" wide. There's also a horizontal masking system and about $10 worth of 2x4" framing.
Tedd is offline
post #9 of 10 Old 03-07-2012, 03:09 PM
Liked: 1905
Though, with two massive subwoofers behind their false wall, I could see where the extra bracing would make it less apt to vibrate during a movie with a rockin' bass-heavy soundtrack.
post #10 of 10 Old 03-07-2012, 03:27 PM
Tedd's Avatar
Liked: 440
Not really a problem. The framing doesn't catch air. What you don't want, is a sub driver (or port) firing onto the screen material or the screen material will move.
Tedd is offline
