Seeking advise, comments on basement build - AVS Forum | Home Theater Discussions And Reviews
Old 03-22-2012, 02:34 PM - Thread Starter
kostia's Avatar
Hi,
I have been thinking for a while on the best use of space and came up with a couple of options that I would like comments on based on your experience.
The goal of basement is to provide a mix of entertainment options for adults mostly, but for kids as well. Hoping that kids (boys 6, 11) would use gym, pool table in the future. Want to have
gym, sauna, bar, billiards, play room, bathroom with shower, wine cellar (small).
Plan A allows for a bigger gym. This also allows for slightly larger bathroom.
However with this plan wine storage is between sauna and furnace (surrounded by heat) which of course is a negative. Also pool table is together with the bar which is what I like, but my wife would prefer not to have together
Sealed off rooms are access rooms to utilities/water etc.
Plan B is missing a new furnace that would be installed to heat basement and which is placed in play room on Plan A.
Anything else that I need to think about? Any suggestions?
kostia is offline
Old 03-22-2012, 02:44 PM
Dan Hitchman's Avatar
Quoted: 3414 Post(s)
Liked: 1767
If you're going to play billiards, you want to make sure you have enough room width or you might have to go with a mini table and not one of regulation size. I don't think your room is wide enough for full stick control. I have the same problem in my basement.
One other thing I like about Plan A is that if you enclose your TV room and drop the pool table area in the back, you end up with a dedicated theater space where you can have full light control, better acoustics, space for proper speaker placement, good sound isolation, and more seating (tiered), and maybe even a bar counter in the back (if you have enough room length) for third row overflow.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
Old 03-22-2012, 03:24 PM - Thread Starter
kostia's Avatar
Both rooms are about 13' wide after walls installed. I believe both should be wide enough for an 8' table and a 52" cue.
Possibly even 9' with 48" or even 52" cues.
Theater is not a consideration right now, but possibly would do as much as possible in preparation for one where the play room is.
kostia is offline
Old 03-22-2012, 03:54 PM
Liked: 1767
I guess we all have our priorities.
There was a theater on here with a multipurpose floor plan and theater room like what you're considering that really looked classy and blended together well. If I could only remember the forum member's name!
They had a full bar and billiards off to the side and a small bar top and stools for the third row seating attached to the second row riser.
Old 03-22-2012, 04:47 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
http://www.billiardfactory.com/plann...ing-guide.aspx
13'2" according to the chart for a 57" cue. 52" and you should be ok with an 8' table. I have a few places around my room that you can hit with the cue onto the furniture or the bar, but honestly, as long as it's not a major obstacle, like a post, normal folks aren't going to care... Now, if you're having league night, different story!
Jeff
jautor is online now
Old 03-28-2012, 10:21 PM - Thread Starter
kostia's Avatar
Have been thinking about it for a while and wanted to get opinions on full blown bar vs just a wall unit I.e. without sitting area. This seems to create more open space and since there is a sitting area right there in front there is no overlap with bar stools couches etc. basically is seating area sufficient and more comfortable as well as cheaper solution. I guess that takes away from the bar feeling somewhat... Thoughts, opinions.
kostia is offline
Old 03-29-2012, 08:14 AM
dRwOOD73's Avatar
Great looking designs.. personally I wouldn't want the bar and pool table as far apart as it is in plan B. Plan A makes the most sense, you just have to convince your wife a pool table and bar are like peanut butter and jelly.. ying and yang.. well, you get the picture.
As far as the "theater" idea, you could throw a flat screen on the near wall in front of the sectional and run a simple speaker set up that way you can have an open view from the bar and pool table area making for a great entertainment space..
Before frequenting the AVS forum, that is the exact type of space I wanted.. after seeing all the fantastic dedicated home theaters here - it will be a tough decision when the time comes.. I have a youngin myself (almost 4), so I understand the need for a play area. Just go with a flexible design for future "upgrades".. good luck.
dRwOOD73 is offline
Old 03-29-2012, 01:14 PM - Thread Starter
kostia's Avatar
Thanks. My wife is now sold on plan A. Yes I am planning on a tv on the wall near sectional that can be viewed from all angles in that room.
I am not a big fan of full blown theater, but will pre-wire play room in case I would want to turn it into home theater in 5-6 years.
Still not sure what to do about the bar, a full blown bar or a walk-up style bar?
kostia is offline
Old 03-30-2012, 11:09 AM
barlav's Avatar
nice plans. I like all the options you are incorporating. If you insulate wine storage room properly and go with a slightly over sized A/C-Humidity control unit for it, the heat from surrounding spaces shouldn't be a factor. Are you contracting out or DIY? Either way I hope you post pics of the progress. Looks to be a good one. Oh, and if not already addressed, don't forget radon mitigation and backup sump system.
barlav is offline
Old 03-30-2012, 01:09 PM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
toofast68 is offline
Old 04-02-2012, 07:45 PM - Thread Starter
kostia's Avatar
And of course now, I need advise on equipment. Should I go with in wall or in ceiling option for the billiards/bar room, 4 or 6 speakers? Any recommendations on particular speakers?
kostia is offline
Old 04-02-2012, 08:20 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
What is your budget?
ack_bk is online now
Old 04-03-2012, 04:37 PM - Thread Starter
kostia's Avatar
Not really sure, I would like it to look nice and sound nice. Given the size of the project I could be somewhat flexible, however I do not want to go overboard either. I would hope under 1K with wiring (this is for speakers and wiring only)? Probably would use Sonos for music control, although it seems that I could probably get a good receiver that would do the same thing especially by the time I am ready to install? Hope this makes sense. Not quite sure what to expect really.
kostia is offline
Old 04-03-2012, 08:44 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Sorry for the questions. Are you wiring and installing these speakers or are you hiring an installer? This will drastically affect the price and the speakers.
Old 04-04-2012, 07:50 AM - Thread Starter
kostia's Avatar
Makes sense... I will be hiring someone, probably whoever does the build/electrician will be doing this.
kostia is offline
Old 04-04-2012, 12:57 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I would have him plan for in-ceiling if this is just for the bar/billiards area. It will most likely be easier and cheaper. It is hard to say 4 or 6 without seeing the space, but more usually seems to be better
These are on a good clearance:
http://www.accessories4less.com/make...de-Each/1.html
Old 04-26-2012, 12:16 PM - Thread Starter
kostia's Avatar
Please let me know what you think about my wiring plans. I am thinking of placing AV equipment in the bar area, cabinets or possibly under the stairs.
AV room
receiver to serve gym and bar room
possibly a Sonos unit or a laptop with HDMI out
I would run
to Gym room (1 DLNA capable TV)
1 HDMI cables
1 CAT 5 to tv
planning on 4 speakers in the gym room so accordingly - 4 sets of wires
Bar/billiards room
1 HDMI cables (1 DLNA capable TV)
1 CAT 5 to tv
planning on6- 8 speakers in the bar room so accordingly - 6-8 sets of wires
would keep the play room completely separate and pre-wire it for potential theater at a later time with its own AV rack
How can output tv audio through the speakers? Basically the idea is to be able to watch stored on PC or Web content on tv. Ideally with sound through the speakers. Alternative is using XBox, PS3 or other device connected to receiver and all content going through receiver. Control of the unit is somewhat cumbersome from the gym room? Can anyone recommend a better solution that is cost effective for the purposes?
kostia is offline
