Any info on OmniMount Power 55 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-25-2012, 09:11 AM - Thread Starter
orthodoc99's Avatar
I was thinking about using the omnimount power 55 for my 55lw6500. I can't find many reviews on the product. Does anyone have any experience, pro's or con's, about this mount. Thanks.
orthodoc99 is offline
post #2 of 4 Old 03-25-2012, 04:13 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Search for power55 over at remotecentral.com for some discussion of that unit.
If you don't have a strong need or it, it seems like something that will break down.
Can't you just make a mount out of used titanium hardware?
You can call one of your non-ortho colleagues to motorize it.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 4 Old 03-25-2012, 07:01 PM - Thread Starter
orthodoc99's Avatar
Maybe I could use some small used intracranial "coils" for the motor.
Appreciate the help. I'll check out that website.
post #4 of 4 Old 03-25-2012, 10:01 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Nah, aneurysm coils are not ferromagnetic.
Trying to share the display, perhaps between the kitchen and FR?
I'm considering a flip down tablet for the kitchen, myself.
Neurorad is offline
