12 Sheets of Owens Corning 703 - Looking for basic acoustic treatmt - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-05-2012, 01:49 PM - Thread Starter
lou99's Avatar
My living room walls have no decoration. The apartment has basic furniture, a sofa, HT equipment, and a 7x10 carpet.
Audyssey reduces the bass of my Tower Speakers below 80hz, which implies that I have bass node issues. Theres some boom going on and echoey high's..
I have 12 Corning 703 boards and cloth that can be used as basic acoustic panels.
What can I do to help this problem and the overall sound in my room? Would I be able to stack several 703's for bass control? Thanks!
lou99 is offline
post #2 of 6 Old 04-05-2012, 01:58 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
No expert at all but seem to me that just turning the room around so your display is on the narrow wall would give you room between your head and your rear speakers.. that in it self I would think should make a major difference.. but what do I know.. I'm still using 2.1 for sound..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 6 Old 04-05-2012, 01:58 PM - Thread Starter
lou99's Avatar
I cant do it since my sofa is too wide and I cant get around it easily.
lou99 is offline
post #4 of 6 Old 04-05-2012, 06:26 PM - Thread Starter
lou99's Avatar
Hopefully I posted in the right section!
lou99 is offline
post #5 of 6 Old 04-07-2012, 07:12 PM - Thread Starter
lou99's Avatar
up?
lou99 is offline
post #6 of 6 Old 04-08-2012, 11:22 PM
stockmonkey2000's Avatar
Liked: 30
How thick is the oc703? Sounds like you need some thick traps in the corners if you want to solve the bass issues. Google super chunk bass traps and that might give you some ideas.
stockmonkey2000 is offline
