Leveling of TV already that's been wall mounted - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-18-2012, 09:43 AM - Thread Starter
Nate2003's Avatar
I have previously wall mounted my 46" LCD. After a week or so I noticed it was a bit off after it was already hung on the mount and confirming this by a level.
Is there any sort of trick I can do to just boost up one side slightly?
This is the mount I have used.
http://www.amazon.com/dp/B000J3HTQG/...60_cs_sce_dp_1
As you see it just hangs on the bracket. Only thing I thought of is getting a small flat flexible piece of medal I can fold over the bracket on the side I wanted to add some height to a re-hang it then on the bracket.
Nate2003 is offline
post #2 of 4 Old 04-18-2012, 10:23 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
That would probably work. Certainly easier than reaming out the holes on the bracket.
Probably wouldn't take too much to do it either.
NickTheGreat is offline
post #3 of 4 Old 04-18-2012, 08:10 PM
yobrigidey's Avatar
Is there any play in the mount if you loosen the lag bolts?
yobrigidey is offline
post #4 of 4 Old 04-18-2012, 08:49 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Also look at the brackets that attach to the TV- many times they can be offset slightly so one side is higher/lower than the other.
Jeff
jautor is online now
