Need advice on bedroom setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-22-2012, 06:40 PM - Thread Starter
Unknown user's Avatar
Hello, I need some help/tips on a bed room setup, rough estimate on the size is 20x20, as of right now its completely empty as we just put new flooring, lights, walls, ect..
Bed size: Queen
T.V: Samsung LED 55inch
Electronics:Xbox 360, Blu ray, DVR for security system, yamaha 5.1
As of right now My plan is do have everything all in front of my bed, however I would like all the wiring very neat and hidden and would like to know on how to go about on this. So I would have to run at least one cable cox wire to the room for cable box what can I buy to not have a lot of wiring show? I just brought this from amazon
http://www.amazon.com/VideoSecu-Fash...5141278&sr=1-4
I also plan on buying wall shelving to place my components on, and any suggestions for this would be great as well. After this is all done I will buy a new 5.1 system probably from HSU and a Denon receiver.
So my main concern is having all the wires neatly and possibly hidden as with this t.v mount I believe everything should be preset cause I can't pull out the t.v and I chose to buy this one as it will save space and keep it nice and flush on the wall.
Unknown user is offline
