Looking for a receiver, diagram inside - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-30-2012, 09:26 AM - Thread Starter
PlayWithFire's Avatar
I am getting ready to buy a projector, and would like an easy way of switching between my current TV and the projector. The diagram is what I have in mind.
As you can see, I need something that would take 4 HDMI inputs, and have 2 HDMI outputs. I also want the ability to output the sound to my TurtleBeach wireless headphones as well as a sound system, which I do not yet have.
Do I have any simple options here?
PlayWithFire is offline
post #2 of 10 Old 04-30-2012, 10:16 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
As long as there's only one active HDMI input and only one HDMI output at a time, what u have is good.
After you have zero in on your receiver's options, come back and ask whether there are any HDMI handshaking (annoying) issue with those.
MrBobb is offline
post #3 of 10 Old 04-30-2012, 10:20 AM - Thread Starter
What do you mean, I am good? I can't seem to find any receivers that can take 4 inputs and have 2 outputs.
post #4 of 10 Old 04-30-2012, 10:34 AM
Kal Rubinson's Avatar
Quoted: 685 Post(s)
Liked: 468
For ?????, substitute speaker cable.
For AVR, you may have to spend more than you think but there are many with dual HDMI outputs. Here are 2 examples:
http://usa.denon.com/US/Product/Page...I%28DenonNA%29
http://www.onkyousa.com/model.cfm?m=...s=Receiver&p=i
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #5 of 10 Old 04-30-2012, 10:39 AM - Thread Starter
Yeah, the price of the receiver is what I was afraid of. Are there no reasonably priced options?
Can I just put get a receiver that has 4 ins and 1 out, and use an HDMI splitter?
post #6 of 10 Old 04-30-2012, 10:45 AM
Quoted: 685 Post(s)
Liked: 468
I do not know much about that part of the market but you can do the leg work by scanning the Denon, Onkyo, Marantz, Yamaha, etc. websites.
Essentially, that is what is in the AVRs but with more options. Most splitters will output only what the lessor of the displays permits.
Kal Rubinson
post #7 of 10 Old 04-30-2012, 10:51 AM - Thread Starter
AVR is Audio Video Receiver, right?
Also, what do you mean by lesser display? My TV is 1080p, and my projector will be the same.
post #8 of 10 Old 04-30-2012, 11:23 AM
Scout's staff's Avatar
1. Yes - AVR means Audio Video Receiver
2. HDMI switches can be trickey when adding another link in the chain
Scout's staff is offline
post #9 of 10 Old 04-30-2012, 02:07 PM
Hockeypuck25's Avatar
Quoted: 12 Post(s)
Putting a Monoprice 1 X 2 splitter in between the AVR and the TV/Projector would work great. Enable you to get a reasonable AVR and the splitter is cheap.
Unless you plan on watching different things on them at the same time.
Hockeypuck25 is offline
post #10 of 10 Old 05-04-2012, 06:40 AM - Thread Starter
Great, thanks for your help. That's what i'll do.
