Show Us Your Concealed LCD screen setup! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-30-2012, 02:41 PM - Thread Starter
RobertC2012's Avatar
I have a multi-use family room that I need to install a modest 46" LCD with speakers. Only catch it must be concealed when not in use to satisfy the home design supervisor. She does not want to see a black screen 'taking the life out of the room'.
Anyone have a photos or ideas that will not cost more than a few K?
RobertC2012 is offline
post #2 of 7 Old 04-30-2012, 04:22 PM
calv1n's Avatar
I don't have any photos but I've seen a great creston system that lowered a large oil painting complete with frame over a 60" plasma screen in one of the show homes across the street (home builder was Birkholz of Edmonton in the SW side).
Cheers
Calvin
calv1n is offline
post #3 of 7 Old 05-02-2012, 04:56 PM
tomagardner's Avatar
I have seen some "one-way mirrors" covering the screen.
tomagardner is offline
post #4 of 7 Old 05-03-2012, 07:31 AM
khankewycz's Avatar
I have seen the mirror as well.
To be honest. As budget as it gets for hiding a screen. Curtains? Or if you could put in a cut in your wall to flush mount the tv, you could just put a painting over it and manually remove the painting if you needed to use the TV.
Yes there are motorized systems, and some very cool "tricks". But at a certain $ it sorta starts to get to the point where is it worth it.. My .02 though.
khankewycz is offline
post #5 of 7 Old 05-03-2012, 08:39 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
You can also use a lift system to have it rise out of a credenza. Lots of folks sell these lift systems, mostly for bedroom use.
jayn_j is offline
post #6 of 7 Old 05-03-2012, 09:20 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Several companies make frames/mounts with retractable art.
http://www.visionartgalleries.com/?p=main
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #7 of 7 Old 05-04-2012, 01:21 AM - Thread Starter
Seriously thought about this and priced one from a company that looked good on the website. I have a problem with buying what amounts to a piece of furniture sight unseen, with no return options. Also, the AV space in these cabinets seems quite limited.
Yes, I am thinking about this one. Anybody have any experience with this company or similar? Downside I could see would be viewing in a frame that is not adjustable for angles. On the other hand it would go well with the room. I have an antique cabinet that I am modifying to hold the av gear. Goal is to walk into the room and not notice the technology.
