Where did you put your Kinnect/Wii Sensor when mounting your flat panel - AVS Forum | Home Theater Discussions And Reviews
Old 06-06-2012, 06:40 AM - Thread Starter
wlcohen's Avatar
Was not sure what forum to put this in, mods please move it if so needed.
Was wonder for those that hung their flat panel on the wall, where did you put your Kinnect & Wii sensors?
I was thinking a small shelf above the TV maybe?
wlcohen is offline
Old 06-06-2012, 08:21 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
I'm an "above the fireplace" TV guy. But in my last place I stuck the Wii sensor underneath the TV with some tape. This place I have it set on the mantle on top of my center channel.
The Kinect is much larger, so I don't think my tape idea would work as well for that . . .
NickTheGreat is offline
Old 06-06-2012, 09:05 AM
Hockeypuck25's Avatar
Quoted: 12 Post(s)
When the stand is removed from a TV, there is a supplied cover plate for the hole that is left. I drilled a couple holes in that and used it as a mounting point for my wii sensor since the tape and velcro always failed. You could also do the same thing with the Kinect or Playstation Eye. Some thin sheet metal and some small nuts and bolts can hold any of them just fine.
Hockeypuck25 is offline
Old 06-06-2012, 11:08 AM - Thread Starter
wlcohen is offline
Old 06-06-2012, 11:26 AM
Todd Lee's Avatar
I used a small shelf mounted an inch or so above the screen. The shelf was cheap, maybe $6 from target. I'll get the particulars from the wife and will post an update later. I'll attach a picture as well. It worked perfectly, very clean looking.
Edit:
It's a plastic shelf from Walmart, $10. I notched out a spot in the back so the cable would fit between the wall and shelf. The hole is only large enough for the cable to fit in it. I used a drill bit and held the bit flat against the shelf, it cut/melted right into the plastic. Worked perfectly. You don't see the cable hanging down from the seated position, the shelf looks like it's resting on top of the tv.
Todd Lee is offline
Old 06-27-2012, 07:38 AM
vivatech's Avatar
How high up from the floor is your shelf/sensor?
vivatech is offline
Old 06-27-2012, 07:44 AM
MuaySteve's Avatar
Quoted: 24 Post(s)
Liked: 31
Our WII sensors rests on top of the center speaker which is about 6" below the TV and about 3' off the floor.
MuaySteve is offline
Old 07-03-2012, 11:39 AM
White fish's Avatar
I have wii only and I cut the end off and wired a 12volt transformer the just plugs in to the wall and then it just rests on my center channel
(My wii is not close to my screen)
been working for awhile and still to shy to post my own build thread
White fish is offline
