need a good store to buy theatre seating or should i buy rooms to go - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-23-2012, 12:51 AM - Thread Starter
mdsniper7's Avatar
Looking at the theater set rooms to go has or are there some good online sights that arnt overpriced
mdsniper7 is offline
post #2 of 3 Old 06-25-2012, 12:58 PM
calv1n's Avatar
Whats overpriced? That means different things to different people. Give us (the forum) your budget and how many chairs you are looking for and you'll likely get some options. My advice is to give Roman a call. He can be found with a quick search of the forums and tell him what you have to spend and what you'd like if it's doable he's the guy that can likely make it happen and bang for the buck his stuff is hard to beat for those on a budget.
Best of luck
Calvin
calv1n is offline
post #3 of 3 Old 06-26-2012, 11:43 AM
nippystix's Avatar
I just noticed this deal in the paper over the weekend, it is for a 3 piece home theater leather recliner set for $881.72. I am not sure where you are at, but I know there are Bel Furniture locations in Houston:
http://www.belfurniture.com/Weekly-Specials-39.html
However, I am not really sure if this is a good deal or not at all. I just recently started looking for sofas/chairs for my theater room as well. Can other please chime in regarding the price of this deal, and if it really is a deal or not? Thanks guys!
nippystix is offline
