Carpet & underlay - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-23-2012, 09:19 AM - Thread Starter
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
Getting new underlay and carpet for the gaming/audio room, and wondering about the underlay. My speakers and subwoofer rest on marble cutting boards. TV is on a free standing stand (50" plasma)
I have purchased two 30M rolls of "Tredaire Dreamwalk 11mm" And concerned would it be too thick, would it cause the speakers, sub and stand to be a bit wobbly?
http://www.tradepriced.co.uk/tredaire_dreamwalk_11mm_carpet_underlay.html
Also planning on getting stairs, bedroom and lounge re-carpetted is this ok to be used for stairs and lounge?
Would it be better to use this in the gaming/audio room?
http://www.tradepriced.co.uk/tredaire_superior_carpet_underlay.html
Gaming/audio room is over a garage, chipboard floorboards. Considering a short pile overall thickness 7-10mm twist carpet.
But then with thicker underlay getting a warmer room in winter (garage is stone cold) and better sound noise reduction
fatbottom is offline
Plasma Hdtv
