Suggestions to cover entryway into theatre room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-23-2012, 12:41 PM - Thread Starter
stevedawg85's Avatar
Quoted: 30 Post(s)
What would y'all suggest to cover this open entry way? Only thing I can come up with is thick red curtains, but where to find some thick enough to stop any light from coming in.
700
stevedawg85 is offline
post #2 of 10 Old 06-23-2012, 01:04 PM
Cocophone's Avatar
Go to Joanns fabrics. They sell light blocking fabric that you can sew to one side of the curtain
stevedawg85 likes this.
==Cocophone==
Cocophone is online now
post #3 of 10 Old 06-27-2012, 05:56 PM - Thread Starter
Quoted: 30 Post(s)
thanks for the tip! will definitely do this!
How about suggestions on where to place the curtain rod, or how to hang the drapes. I'm thinking hanging the rod on the outside of the room.
Whats the nicest way to handle this? place curtains on both ends? in the doorway itself?
post #4 of 10 Old 06-28-2012, 01:41 PM
cheezit73's Avatar
Quoted: 13 Post(s)
Liked: 24
I have a very similar doorway as yours, I used four curtains, two side by side on the outside and another two side by side on the inside, the dual curtains really helps and blocks 99% of the light out of my room. I just realized I dont have any pictures of my entry in my build thread, I will try and take some for you tomorrow. My curtain rods are probably only about two inches above the opening, most important is that you extended the rods long enough on the sides to allow the curtain to overlap the walls enough to not let the light seep through.
cheezit73 is online now
post #5 of 10 Old 06-28-2012, 01:56 PM - Thread Starter
Quoted: 30 Post(s)
yes please do send/upload pics! I'd like to see how the finished product looks like!
Looking forward to pics, otherwise I'll be bothering you next week for them :P
post #6 of 10 Old 06-29-2012, 11:09 AM
cheezit73's Avatar
Quoted: 13 Post(s)
Liked: 24
Ok here are the pics, sorry about the quality, only had time to use the camera phone. I am happy with the looks vs the cost of installing a nice enough door that I would have wanted.
Outside looking in
Inside Looking out
Outside closed
Detail of dual curtains
Curtain holders on the inside only for holding open
Hope this helps, curtain rods are from Lowes and curtains from a local fabric shop.
The ones on the outside are a more durable material and the inside ones are a nice suede.
post #7 of 10 Old 06-29-2012, 11:20 AM - Thread Starter
Quoted: 30 Post(s)
Awesome! thanks for the pics. Definitely going to help me in my final decision. When it's finally made, i'll make sure to post pics.
post #8 of 10 Old 06-29-2012, 01:33 PM
cheezit73's Avatar
Quoted: 13 Post(s)
Liked: 24
Great! I noticed you have lots of separate threads with questions. Have you made a build log in the dedicated theatre section? Maybe I missed it.
post #9 of 10 Old 06-30-2012, 08:48 AM - Thread Starter
Quoted: 30 Post(s)
Thanks for noticing :P.
I was thinking bout making one, guess it's time to set one up. I'll snap a few pics and create a thread by next week. I'll let you know in case your interested.
post #10 of 10 Old 06-30-2012, 12:18 PM
cheezit73's Avatar
Quoted: 13 Post(s)
Liked: 24
Cool, your room just looks a lot like mine before I started on it so looking forward to seeing what you do with it.
