What is considered a small, medium and large size rooms? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-26-2012, 09:55 AM - Thread Starter
Szeppelin75's Avatar
Any thoughts on the size of each one?
Szeppelin75 is offline
post #2 of 5 Old 06-27-2012, 05:59 PM
Scout's staff's Avatar
I'm sure each manufacture varies slightly to what they consider a small, medium or large room, but I used the estimates from the speaker manufacturer, Atlantic Technology since I have Atlantic's.
Per their web site:
Small - Medium <1,800 cu. ft.
Medium 1,800 - 2,500 cu. ft.
Medium to Large 2,500 - 5,000 cu. ft.
large >5,000 cu. ft.
Hope this helps
Scout's staff is offline
post #3 of 5 Old 06-28-2012, 03:03 PM - Thread Starter
Thanks, so if my living room is 20 x 14 x 7 feet, that would make it 1960 cu. ft. a medium size room.
post #4 of 5 Old 06-29-2012, 09:24 AM
Correct - however, if the room is open to another room, you should also include a portion of that space as well.
post #5 of 5 Old 06-29-2012, 10:59 AM - Thread Starter
The room is open the the dinning room in one portion which is next to a semi-open kitchen.
