Exposed ceiling and speaker choice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-02-2012, 06:20 AM - Thread Starter
cavsforum's Avatar
All,
I'm looking for advice in purchasing rear speakers. This is for my basement in which I have the ceiling joists exposed. I had planned to buy some in-ceiling speakers, but they all seem to clip onto Sheetrock. I'm also trying to avoid freestanding speakers. So, are there any alternatives? Any ideas? Thanks!
cavsforum is offline
post #2 of 5 Old 07-02-2012, 08:39 AM
NickTheGreat's Avatar
Quoted: 435 Post(s)
Liked: 307
So you're not going to put ceiling in? If so, can't you just run a little strut across the joists to attach the speaker to? If it was the same thickness as the sheetrock, you could clip to that.
NickTheGreat is offline
post #3 of 5 Old 07-02-2012, 08:51 AM - Thread Starter
cavsforum's Avatar
That's correct, there will be no ceiling. Hmm, I'll have to look into the strut recommendation. I am quite unhandy though smile.gif
Do in-ceiling speakers do well in an open air environment?
post #4 of 5 Old 07-02-2012, 04:43 PM
tbraden32's Avatar
Look at Triad in ceiling speakers. They come within their own backer box. Not sure of your budget as they are not cheap, but great product!
Sent from my iPad
tbraden32 is offline
post #5 of 5 Old 07-03-2012, 04:23 AM - Thread Starter
cavsforum's Avatar
Thanks, I'll look into that brand.
