Placing acoustic material behind pantings? - AVS Forum | Home Theater Discussions And Reviews
Old 07-02-2012, 07:54 PM - Thread Starter
zirconx's Avatar
Hi, I'm trying to reduce some of the echo in my living room when watching movies. Its about 18x25" with a 15" peaked ceiling. The reflections in this room are so bad that its hard to understand dialog in a movie. When I pause a movie, you can hear the sound continue in the room for a portion of a second.
We have two 3x5 oil painted canvas frames on the rear wall. I am thinking of buying 1" acoustic material and placing it behind the paintings. But I know the oil painted canvas is not as transparent as speaker cloth. My question is, do you think this would help at all? Here is a crude diagram of the room.
0 = speaker
x = painting
Code:
_________________________
|                  0    { TV }    0                  |
|        {  couch  }     {  couch  }          |
|_0________x____x_______0_ |
(sorry I can't seem to make this work on these forums. Hopefully you get the idea)
zirconx is offline
Old 07-02-2012, 09:20 PM
jautor's Avatar
Quoted: 1225 Post(s)
Liked: 787
I don't think that will do much good - an oil covered canvas is pretty reflective, and it's that mid-high range area that you're concerned with... Better to concentrate your efforts on the side walls - there are lots of attractive options for acoustic wall panels. You might start by just bringing more soft stuff into the room, too - pillows, blankets, etc. If there's not carpet in the room, a nice thick rug would be a big plus.
Jeff
jautor is offline
Old 07-03-2012, 03:53 PM - Thread Starter
zirconx's Avatar
Here is a diagram that is more accurate. As you can see, I can't really put panels on my side walls either.
I guess I should purchase real panels and maybe replace the painted canvas with them?
387
zirconx is offline
Old 07-04-2012, 09:11 AM
jautor's Avatar
Liked: 787
What's the flooring material? If the room is echoing that badly I think you're going to need something more than a couple of wall panels...
Jeff
jautor is offline
