Help With Odd Room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-03-2012, 08:37 AM - Thread Starter
wlcohen's Avatar
The delema is where to put TV & tower speakers
On the TV wall there is a utility closet in the corner which puts the TV in an odd space.
If I center the TV for the wall where the seating goes it will be 5" from the closet wall which gives me not much room for speakers
Slim towers will fit but the left speak will block some of tv for far left chair
I am thinking of just moving the TV to the right and having it off center on back wall
465
wlcohen is offline
post #2 of 4 Old 07-05-2012, 11:45 AM
NickTheGreat's Avatar
Quoted: 386 Post(s)
Liked: 259
Is the closet the 3'-3" opening? Because depending on whats happening in this room, that 11'-2" wall looks like a good place for a TV
NickTheGreat is offline
post #3 of 4 Old 07-05-2012, 11:50 AM - Thread Starter
wlcohen's Avatar
No that leads to the stairs
The closed it is in the top left corner
1/2 of the 11" wall is open and has the stair railing
wlcohen is offline
post #4 of 4 Old 07-05-2012, 12:16 PM
Quoted: 386 Post(s)
Liked: 259
Hmmm . . . I see. Your idea is probably best. Unless the "bottom" wall would work. Don't know how that'd be with the stair entrance there.
