Power Connection Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-06-2012, 09:55 AM - Thread Starter
blestj02's Avatar
Hello,
I have recently moved into an appartment and have bought some new AV gear. Ive had my 55 in led tv for about 3 weeks and recently bough a new samsung soundbar. I was using the soundbar for about 5 min when i heard a pop and the soundbar turn off and then back on. The sound is now crackly and distorted. Im not sure if this was just a bad soundbar or if this was caused by having it plugged into a dynex(cheap)surge protector. Should i get myself some sort of UPS or better surge protector. My TV and Xbox are plugged directly into the wall and haven't had any problems yet(knock on wood). I just dont know what to do, is a surge protector enough or should i get a UPS. Im not looking to spend a lot but want to get whats right. Please, any info on this would be great, im driving myself crazy with this.
blestj02 is offline
post #2 of 4 Old 07-06-2012, 10:40 AM
spivonious's Avatar
It sounds like a defective soundbar, and nothing related to the power strip.
spivonious is offline
post #3 of 4 Old 07-06-2012, 10:50 AM - Thread Starter
blestj02's Avatar
Thanks. Would you recommend moving my tv and xbox from the wall plug to a surge protector?
blestj02 is offline
post #4 of 4 Old 07-06-2012, 08:08 PM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
Well, it's not going to stop surges, etc. to the expensive stuff not plugged into it! There are plenty of small wall-plug-sized surge protectors, too, if the strip isn't closeby...
jautor is offline
