Tv niche easy remodel to fit tv question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-23-2012, 08:44 PM - Thread Starter
Popeeta's Avatar
So I'm about to close on this house and the tv niche is too small for my 60 Panasonic
http://www.flickr.com/photos/82796994@N02/7634593292/
The 2x4 that I have the arrow pointed to is too small to attach mount to. I'm not very handy so I wanted to try a simple fix and was wondering what you guys thought. My initial thought is to just attach a 2x8 on top on it (the 2x4 is slightly recessed so it should fit well) then just paint it in case I ever extend the mount of rotate it. And then just attach the tv to that. Maybe drywall the rest of the opening below the tv would not cover. That way I could still pull tv out and easily get to wires. So do you think that the 2x8 attached to 2x4 then maybe screwed diaganoly into the wall would be secure enough for 100 lbs or so?
Like I said l, I'm not very great at this stuff and this may be a terrible idea but I can't think of any easier fix. Any recommendations would be appreciated!
Pete
Popeeta is offline
post #2 of 6 Old 07-24-2012, 07:54 AM
Magguss's Avatar
Or you could cut that board out and mount an articulating mount all the way to the back of the niche. Just need to make sure you get one that pulls out enough to clear the niche.
Magguss is offline
post #3 of 6 Old 07-24-2012, 12:17 PM - Thread Starter
Popeeta's Avatar
It's possible but it's pretty deep. Thanks though I'll check it out.
Popeeta is offline
post #4 of 6 Old 07-24-2012, 01:39 PM
Magguss's Avatar
Or depending on how well it is framed out, mount an articulating mount inside the niche to the left or the right inside wall.
Magguss is offline
post #5 of 6 Old 07-25-2012, 08:17 AM
NickTheGreat's Avatar
Quoted: 425 Post(s)
Liked: 304
How deep is the niche? And how wide? i would think you could some how affix a couple 2x6's to put your mount on, though it might be too wide.
Or how about a ceiling mount up inside the niche? Never used one, but they make them.
NickTheGreat is offline
post #6 of 6 Old 08-14-2012, 04:39 PM - Thread Starter
Popeeta's Avatar
Just demo'd and this is result before painting.
Popeeta is offline
Panasonic , Displays
