50; run, HDMI or Cat to HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-31-2012, 05:19 PM - Thread Starter
LucasBuck's Avatar
I've got a couple runs of HDMI to run, one 30' one 50'. Would I be better off running a long HDMI cable or a Cat (5e or 6) to HDMI faceplate converter? I wasn't sure if I would have less signal loss or interference with one of the other at that length. Unless I'm figuring wrong, the prices seem pretty close. Thanks for any info.
LucasBuck is offline
post #2 of 5 Old 08-01-2012, 10:17 AM
wadepoe's Avatar
I would say HDMI over cat5 if the cost is the same, one less point of failure is always good. Just get the right length and 2 HDMI faceplates and do it right.
The only thing to consider is make sure you have enough cable (to ceiling, run, from ceiling, +15% error). With HDMI you are paying for the cable, Cat5 you are paying for the face plates (they are now $16 on monoprice.com I just picked up 4).
I went Cat5 at my house because 150' runs, no complaints so far.
wadepoe is offline
post #3 of 5 Old 08-02-2012, 12:19 PM - Thread Starter
LucasBuck's Avatar
Thanks for the reply. I just didn't know if the quality is the same.
post #4 of 5 Old 08-02-2012, 12:48 PM
jmhug's Avatar
FYI- check out the anniversary sale page at monoprice. They have a 50' 22 AWG hdmi cable at a good price.
I just hooked up the HDMI wall plate extenders that run over CAT 6 last night and they work as advertised. I went that route due to the number of turns etc I had to make between the connections. The cost was less than the hdmi cable, however I had extra CAT 6 already available to make my own CAT cable lengths.
jmhug is offline
post #5 of 5 Old 08-03-2012, 07:30 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 633
I would grab the Monoprice cable and also run a couple of Cat 6 cables, if you are talking about running cables through walls...
ack_bk is offline
