Any advice for a very novice carpenter on building a bar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-16-2012, 05:11 AM - Thread Starter
cleland500's Avatar
I found this and really like the idea for our media room downstairs. I like the bar behind the couch in the first two pictures and would like to something similar.
http://www.houzz.com/sofa-bar/ls=1
Does anyone have any advice on how to build it? I've been searching all over online for plans for other pictures but I've found very few...
cleland500 is offline
post #2 of 4 Old 08-16-2012, 07:42 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 131
Have you tried searching this forum and the archives of this forum There is a really large thread on bars and some fantastic work. I'll see if I can dig it up.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 4 Old 08-17-2012, 12:23 PM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 131
OK, found the one thread I was thinking of. But only because the thread starter happened to chime in on another thread with a link to his thread. I wasn't searching back far enough! His thread started in '06! Check out the HeyNow^ bar build here.
Tom Logan
post #4 of 4 Old 08-19-2012, 07:20 PM - Thread Starter
cleland500's Avatar
Awesome, thanks. I'll check it out.
