Help me spend my money: starting from scratch on my HT equipment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-16-2012, 12:54 PM - Thread Starter
fmaz's Avatar
Hi all -
After years of piece meal upgrades, we're redoing our entire family room and kitchen in our home... and it makes a perfect time to retire some equipment and start from scratch. It's been years since I've been in the market for speakers, and my receiver has got to be 8-9 years old as well... so I've been out of the loop for a while!
The basics of the room is that it's about a 25x20 space... but an open floor plan so behind the room it continues to an open kitchen area and a dining room.. so it's pretty big. But the living room itself will be the 25x20 space.
For a TV, I'm pretty set on the Panasonic TC-P65ST50. Might go with the 60"... but either or. I've got a P50UT now which will move to another room and I really like it.
Existing equipment which will remain will be a Directv-HD-DVR (3D enabled... but I'm not too concerned about 3D) and at least one gaming system either an XBox or a Wii.
So my biggest concerns are which BR players are the best bang for the buck, and what AV receiver I can get that will be able to handle everything well.
And then the speakers.
I'll be able to make room for a floor standing sub, and I'm going to have shelving built to accommodate a center channel above the TV.
But my issue will be fronts and surround speakers. I don't think I'll have the ability to do standing speakers in the front... they'll have to be able to fit on shelving, or perhaps be wall mounted.
Same goes with the surrounds.
So smaller will be better, but I don't want to skimp on sound or power if possible... because there will be times when we're using the system to fill the larger, open space.
Budget wise? I've been trying to guess at things... but I was thinking $600 for a receiver, $200 for BR, and $1,200 for speakers?
Is that reasonable? Too much, not enough?
Sorry for such an open ended question, but I'm really trying to make sure we do it right... considering I know how long it's been since I last bought speakers. My fronts are probably from the early 90's... so I'm going to call Polk and see if they have a "hall of fame" I can send these to to be on display. :-)
Thanks so much,
Frank
fmaz is offline
post #2 of 4 Old 08-17-2012, 01:13 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Hi Fmaz, welcome to AVS!
First, I'm glad to hear you really like your UT50 because that's what I'm looking to buy soon. I've pretty much just finished my home theater with the exception of a nice big TV. For a blu-ray player I recommend Panasonic 220. I haven't read up on this years models, but the 210 from last year was a great model. Otherwise the Sony S590. I have the S580 and it was supposed to be neck and neck for the best players last year, excluding Oppo of course. I think either of those are around $150 this year, while last year they were closer to $200. For a receiver, I'm very happy with my Yamaha V667 (2 year old model), I think the x67 series was the last to have multi-channel input, I don't know if that's important to you or not, but it seems that feature is being phased out. If you ever plan on getting an amp to power your speakers then you'll want pre-outs on the receiver, I think for Yamaha it starts with either the 500 or 600 series. I purchased my receiver 9 months ago from Newegg as a refurbished unit and paid like 40% of MSRP, so refurbished is always a possible way to go to save money and get a great deal. Many folks here also like Onkyo, Denon, and Pioneer for receiver brands. Somewhere in the $600 range for a receiver will get you plenty of inputs for anything you might need. If you're planning on connecting a PC you'll always be able to use and HDMI port for video out but there are select receivers that have a VGA connector on them. For speakers, I don't know what you have or what you're looking for to be either an upgrade or just to replace them with something new, but I chose to go with Polk speakers for my set up and they perform very well. I have Monitor 40s for the fronts, Monitor 30s for the rear, and a CS20 (or is it a CS2? Whichever the older model is). The 30s and 40s are bookshelf speakers and the 30s have a mount on the back that you could hang them from a screw (or whatever the proper way to hang a speaker is). I think for my 5.1 speaker setup, with receiver, I probably paid about $1000 because I waited for good deals at Newegg. For a sub, I chose to DIY a Bill Fitzmaurice's Tuba HT sub. They cost about $500 in lumber and parts, including the driver and amp. If you like to do DIY projects then this could be a great option. The sub is quite large, it measures 36" H x 24.5" D x 36" W but it's supposed to be unrivaled by anything for the price. And it can shake the walls pretty easily. My living room is pretty small, it's 13' x 13' but I know a lot of members here have rooms closer in size to yours and can probably give better ideas on how to fill the space with sound better. I hope this helps and gives you some ideas for your new HT. Enjoy it when it's all finished!
anikun07 is offline
post #3 of 4 Old 08-18-2012, 12:30 PM - Thread Starter
fmaz's Avatar
Thanks for the welcome, and the tips. I've been checking a lot out through cnet and here, but just haven't really found a concensus yet .... especially on the speakers!
fmaz is offline
post #4 of 4 Old 09-07-2012, 03:41 PM
Treyster's Avatar
I love my Salk speakers. Check out Salk Sound, Jim Salk is great to work with. He can put you in some great sound at various budgets. I just read a great review for the new Onkyo TX-NR5010. I have the TX-NR1007. No complaints. Oppo BluRay player.
Just my 2 cents.
Treyster is offline
Panasonic Viera Tc P65st50 Plasma Tv , Plasma Hdtv , Displays , Panasonic Viera Tc P50ut50 50 Inch Plasma Tv , Directv , Microsoft Xbox
