5+ years since my last theater upgrade. What would you do? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-17-2012, 02:06 PM - Thread Starter
roadratx's Avatar
I have a dedicated theater (21d x 15w x 10h) with the following setup:
TV: Mitsubishi WS55413 (connected via Component)
Receiver: Yamaha RX V-1200
Speakers: 2 Atlantic Technology 4200e (L/R Front)
1 Atlantic Technology 4200e (Center)
2 Atlantic Technology 6.3e (Ceiling)
Mirage Sub
Dish Network VIP722 DVR (connected via Component)
Sony DVPNC685V (connected via Composite)
WD TV Live (latest generation) (connected via Composite directly to TV - here's why
50% of what I watch is via Dish Network, 48% is streaming video via the WD TV Live, 2% is DVD. I don't buy/rent Blu Rays often.
I know the receiver needs to be upgraded to allow for HDMI connections.
What receiver would you buy and what would you do beyond a new receiver assuming a $3000 or so budget?
roadratx is offline
post #2 of 4 Old 09-17-2012, 06:12 PM
Nick_si's Avatar
Personally I would go this way for a receiver. http://www.accessories4less.com/make-a-store/item/DENAVR3312CI/DENON-AVR-3312CI-7.2-Integrated-Network-A/V-Surround-Receiver/1.html but a comparable unit from Yamaha if you have a loyalty is just as good.
A new receiver will get you room adjustment, HDMI and the newest HD audio formats via blu ray. I would get a blu ray player and try renting a disc or two from RedBox or Netflix, they really are worth it, especially for the audio as streamed audio is not that great.
Your speakers seem good, if you like them then no need to upgrade. I would use the rest of the moneys to get a new TV. What TV is a way bigger question than I am ready to answer, though i belong to team plasma so I would say go that way.
Nick_si is offline
post #3 of 4 Old 10-02-2012, 09:34 PM
Sindy Ahh's Avatar
Just to be clear, which WDTV Live do you have? The one that needs a wifi dongle and smaller remote, or the newer one with the bigger remote that has wifi built in?
I have two different media players (a Patriot box office, and a WDTV Live). The WDTV Live has the built in wifi. If I recall correctly from the Live manual, the factory setting for audio out is supposed to be via composite. I say supposed to be, because when I bought my WDTV (it was refurb'ed) for some reason it was set to HDMI in the menu. Check to make sure the audio out on yours is in fact set to composite and not HDMI.
When you get a new AV receiver that has all the extra goodies, make sure to set the WDTV to HDMI, and then set the audio out for whatever format your receiver uses.
Sindy Ahh is offline
post #4 of 4 Old 10-03-2012, 07:59 AM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
$3K. Easily puts you into a modern receiver like the Dennon mentioned above and if this is a dedicated home theater, you need to go with a projector smile.gif
You can easily do this for $3K. I would look into the Optoma HD33, Acer BD9500, and BenQ W7000 projectors. A whole package (projector, screen, mount, cables, etc) would be roughly $1700-1800 with the Optoma. The BenQ. which is the projector I recommend, would be $2300-2400 for the package (pj, screen, mount, cables, etc):
http://www.visualapex.com/projector-package-deals/BenQ-projector-packages.asp?for-the=W7000
Definitely the way to go for your money.
ack_bk is offline
