Need suggestions/ideas for a corner mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-01-2012, 07:18 PM - Thread Starter
MitchV's Avatar
I'd like to mount a 42" LCD television in our bedroom, and provide a shelf for a TiVoHD DVR. I've had success with Monoprice.com in the past, based on advice I received through these forums.
Perhaps my biggest concern is my odd-ball stud placement. I've attached a picture I took while my home was being built. On one side of the corner I have 11.5 inches to the nearest stud. On the other side, I have 22 inches (is that up to building code?)
I don't have the weight of my TV handy, but I'm approaching this with the idea that there is no harm in using a mount that exeeds the amount of weight it is expected to hold.
Thoughts? Ideas? Any input would be appreciated!
Mitch
MitchV is offline
post #2 of 2 Old 10-01-2012, 08:04 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 920
I have a 47" LED LCD hung in the corner with one of these: http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082806&p_id=5087&seq=1&format=2 I used a plate under it. Here's a couple of pictures of it: http://www.avsforum.com/t/1325725/mounting-lcd-tv-against-window-facing-outdoors/0_40#post_20241321
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
