Rear speaker distance? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-07-2012, 03:33 PM - Thread Starter
stanwelks's Avatar
What distance should rear speakers be placed from where you are sitting?
stanwelks is offline
post #2 of 5 Old 10-08-2012, 02:19 PM
Scout's staff's Avatar
I've read someplace at least 4'. I have mine set at approx 8 - 12' depending on where you sit and have been happy with the result. You should also use Audyssey if you have it to help adjust (i also did some manual over-riding with an SPL as well)
Scout's staff is offline
post #3 of 5 Old 10-13-2012, 09:58 AM
mn_hokie's Avatar
Liked: 27
I agree with the 3-4 foot range, and more is always better. This typically applies more to freestanding speakers than mounted ones. Having speakers (or seating) too close to walls or corners results in a lot of low-end buildup that can degrade the quality of the sound.
mn_hokie is offline
post #4 of 5 Old 10-15-2012, 09:13 AM
vivatech's Avatar
Are your rears on stands, walls, ceilings?
vivatech is offline
post #5 of 5 Old 10-21-2012, 08:35 PM - Thread Starter
stanwelks's Avatar
My rears are currently on stands, though I am looking into getting speakers eventually placed into the wall behind my sofa so they will be flush with the wall.
