Living room & home treater - AVS Forum | Home Theater Discussions And Reviews
Old 10-09-2012, 01:55 PM - Thread Starter
fekish's Avatar
Hello,
I am building a new house, and i am considering to have provision for possible projector. What wires should i consider installing? Just an hdmi cable coming down to a specific point behind sitting position for example? And then audio cable going to the front for speakers?
Sent from my XT910 using Tapatalk 2
fekish is offline
Old 10-09-2012, 02:26 PM
mn_hokie's Avatar
Liked: 27
It depends on what type of inputs you want to be using with the projector. Most projectors have pretty much everything on them now. Even though I just use HDMI on mine, I still ran a backup cable, as well as a set of component cables just in case I ever need them.
For audio, I'm guessing you'd want to do surround sound, so you'd be looking at a minimum of 5 speaker cables (plus the subwoofer) back to where you're storing your receiver.
mn_hokie is offline
Old 10-09-2012, 10:16 PM - Thread Starter
fekish's Avatar
Ok thanks,
I will have audio provisions, i will have also provisions for antenna and hdmi...
I searched a bit and I don't think i would need anything else.... Pretty much everything its covered by these two.
Thanks again!
fekish is offline
