Location of AV components with projector setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-12-2012, 06:10 AM - Thread Starter
Charlie Runkle's Avatar
Wondering where people are placing their AV components with projector setups? Do you typically locate them at the front of the room or towards the back, closer to the projector?
Curious.
Charlie Runkle is offline
post #2 of 8 Old 10-12-2012, 07:44 AM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
You'll get a mix of answers that probably depends more on what space is available in the room, more than preference. I think most folks would agree that given the choice, having the gear in the back or on the side of the room is preferred. But not because of the distance to the projector. Rather, gear in the front can be distracting (lights, displays, etc.), and it's inconvenient to access while the projector is in use. Much easier to deal with something without walking in front of everyone and putting the shadow of your head in the middle of the image. biggrin.gif
Jeff
jautor is offline
post #3 of 8 Old 10-12-2012, 07:59 AM
AUrator's Avatar
Depends on what you plan on using for a rack and maybe type and number of components you will be using. Also if you don't plan on installing and using a repeater, you may not have much choice but front so that your remotes are functional. Sorry if that is elementary, but I did not know what a repeater was until joining this Site a few months ago. Learning something new each day. I used a $40 black pressed wood rack found on craigslist. put it in the back right of my room and the remotes still work:) if pointed up eek.gif
If you really love your country, you're gonna have to love moonshine
AUrator is offline
post #4 of 8 Old 10-12-2012, 08:50 AM - Thread Starter
Your comments are good ones. I had originally thought locating them at the front of the room but I'm now starting to think that maybe along a side wall might be best. My room layout is awkward at best. Attached is sketch of the layout. I am also looking for suggestions on speaker placement and/or seating arrangements that could help me optimize the visual and audio performance.
20121009103616160.pdf 48k .pdf file
post #5 of 8 Old 10-13-2012, 10:50 AM
mn_hokie's Avatar
Liked: 27
Ideally, you want you'd want your HDMI run to the projector to be as short as possible to minimize any signal issues. However, a lot of times the projector ends up being mounted in the middle of the room, so it's about the same distance to the front as it is the back. From my experience, the ONLY advantage to having equipment in the front of the room is that you can just point the remote at everything and not have to worry about repeaters or IR/RF converters.
That being said, my current and past two theaters have had equipment mounted 1) slightly behind the seating, 2) just to the side and in front of the seating, and 3) in the back of the room. Neither of these options caused me any distractions or took away from the movie experience. My current build has the equipment in the very back of the room, which I do tend to prefer. It's also in a central point to the larger area of the basement so that is can easily be accessed during parties and get togethers as well.
Based on the PDF you just uploaded, I'd go with installing the equipment in the side wall under the stairs. You'd have access to the rear without any additional construction, and the heat would vent naturally through that cavity.
mn_hokie is offline
post #6 of 8 Old 10-13-2012, 05:23 PM - Thread Starter
Your suggestion about placing the AC components under the stairs is a great one. The only challenge with that is running speaker wire to the fronts, center and sub, since the room is finished. What options are out there to assist in this situation?
post #7 of 8 Old 10-13-2012, 05:29 PM
Wytchone's Avatar
Quoted: 36 Post(s)
Liked: 48
I have all but one AV gear in the back. Less lights to distract.
Wytchone is offline
post #8 of 8 Old 10-14-2012, 08:03 PM
mn_hokie's Avatar
Liked: 27
Is there any type of stage or riser in the front of the room? Otherwise, you can always go under the carpet near the screen wall or even behind the baseboards with some of the flat cables designed for this approach.
mn_hokie is offline
