Paint advice for a vaulted ceiling room? - AVS Forum | Home Theater Discussions And Reviews
Old 11-08-2012, 01:05 PM - Thread Starter
pitbull30's Avatar
I plan to turn one room in my house into a media/game room. The room I want to use has tall vaulted acoustic (popcorn texture) ceilings and two large windows on one side that I plan to use black out curtains on. The room is currently all white with dark carpet. I noticed most say go as dark as possible, but If I was to leave the ceiling white would that have any effect on the room? Or should I keep it all one color? (The reason i consider leaving the ceiling alone is because it will be a huge pain in the A** to paint.) What are some color choices I should consider or is it all just a matter of personal preference? I plan to use a projector and screen in this room. Let me know if you need more info.
Thanks for the input.
pitbull30 is offline
