Running wires up wall? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-09-2012, 05:30 PM - Thread Starter
stanwelks's Avatar
I need to run some speaker wire and an HDMI cable from where my TV is located above a fireplace and down the side of the fireplace to under the carpet. Can anyone recommend a way to attach the wires to the side of the fireplace in some enclosure or using some clip?
stanwelks is offline
post #2 of 2 Old 11-10-2012, 07:40 AM
mamwam's Avatar
Wiremold is probably you best bet. But, you would be much happier if you go through the work to route the cables inside the wall.
mamwam is offline
