Wiring speakers and leaving the wire accessible for later. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-12-2012, 10:46 AM - Thread Starter
kerednai's Avatar
I would like to wire a room for side surrounds but not actually add the speakers today.
What is my best option? One of the walls is an outside wall and needs to be vapor sealed so I'm thinking of using a single gang outlet in the wall with a gasket. The problem with this is that it very big compared to the single wire thats required. Can anyone suggest a better solution?
kerednai is offline
post #2 of 4 Old 11-12-2012, 12:25 PM
Scout's staff's Avatar
Is there a way to leave the wire sealed within the wall and have some sort of mark on the wall or detail measurement to expose it later?
You could install a speaker terminal plate and have it look fancy - this method also taunts you to buy more speakers....rolleyes.gif
here is a link to a terminal plate:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10425&cs_id=1042503&p_id=3324&seq=1&format=2
Scout's staff is offline
post #3 of 4 Old 11-12-2012, 12:45 PM
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
I would leave the cable buried behind drywall until I installed the speaker, in-wall. Then, I'd use a keystone plate, single gang, over a low-voltage bracket.
If you can be present during drywalling, you can easily have the drywallers pass a cable through a grommet.
If the speaker will hide the drywall pass-through (plate or grommet), then you can just pass it through the drywall without a grommet, low-voltage plate, or junction box. This would be for on-wall speakers.
I came up with the idea of a half-gang plate a few years ago; production has yet to commence.
http://cocoontech.com/forums/topic/13053-12-14-gang-brackets-wall-plates/#entry111403
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 4 Old 11-12-2012, 02:00 PM - Thread Starter
kerednai's Avatar
Thanks for the response. I agree re the half-gang plate btw and read your post earlier today :-)
The problem with the low-voltage plate or grommet is that its an outside wall and so I need a box with a vapor seal / gasket. As the boxes are not 100% sealed around the wire I don't really see what this buys me but anyway I believe that is what I am supposed to do.
kerednai is offline
