Happy Thankgiving!! What am I missing with this (??) connector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 11-21-2012, 10:12 PM - Thread Starter
SBI
SBI's Avatar
I run cables in the walls of my finished basement for speakers, and also a CAT6 for a subwoofer. I bought an OSD WP16 wall plate for my speakers. It has two RCA connectors for sub and on the back it has what looked like to me as a RG6 connector. Didn't examine it too much.
When I tried to connect my RG6 connector to the plate it would not go in. Further investigation revealed that it's not a RG6. It is similar to RG6, but the screw is smaller (male) than RG6.
What in the world is it and how do I connect it to my RG6? I tried to look for a good picture of this connection but couldn't find anything. I may have to take a close up picture of what I have. There is a picture here but it is not in an angle so it's kind'a hard to see these connections. The front is RCA and it's fine, but the back is driving me crazy.
Thanks for your help and Happy Thanksgiving!
SBI is offline
post #2 of 20 Old 11-22-2012, 07:54 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Have you tried multiple F-connectors? Did you add the F-connector to the cable?
Does your coax cable have a BNC connector, perhaps?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 20 Old 11-22-2012, 08:20 AM - Thread Starter
SBI
SBI's Avatar
Thanks Neurorad.
I didn't try anything yet, I don't even know where to start, I don't know what kind of connection this is. Here is a pic of it that I just took. I have two to connect two subs. The front is fine, it's a straight forward RCA plug.
SBI is offline
post #4 of 20 Old 11-22-2012, 09:40 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Yep, it's a coax F-connector. The spec sheet even says that (RCA to F-connector)... The center support is for the coax conductor to slide into. With the depth of that assembly, it may require you to re-make the coax connection with enough insulation removed to get it to fit. Although it may be intended to seat under the insulation, too.
Can't say I've seen one made like that, but that's what it is... You might try pushing a bare coax cable onto the back to see how it's supposed to work, first.
Jeff
jautor is offline
post #5 of 20 Old 11-22-2012, 09:53 AM - Thread Starter
SBI
SBI's Avatar
Jeff
Is F connector the same as RG6?
I know the spec sheet says that, but I took a bare RG6 connector it won't even screw in, it is larger than this screw, so it doesn't make sense.
Also, the center support is blocked, the coax conductor won't even go in all the way through. I thought about cutting the coax conductor, but before doing this I tried with a bare connector as mentioned above and it won't screw.
Something doesn't make sense.
SBI is offline
post #6 of 20 Old 11-22-2012, 03:00 PM
Frosteh's Avatar
You sure that's a connector? It just looks a lot like a solder tab...
Frosteh is offline
post #7 of 20 Old 11-22-2012, 04:07 PM - Thread Starter
SBI
SBI's Avatar
Could be, so what is the screw for? And it says on the specs RCA to F.
SBI is offline
post #8 of 20 Old 11-22-2012, 05:37 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I've never seen that.
There is supposed to be a hole, where that pin is sticking out.
I'd grab that pin with a pliers, and pull straight back, hopefully exposing a hole.
If you feel like being adventurous, try that, if you can't wait for Monoprice tech support. If you can wait, call TS, and email the support guy that pic.
Neurorad is offline
post #9 of 20 Old 11-22-2012, 05:53 PM - Thread Starter
SBI
SBI's Avatar
Few issues with that:
2. Even if I pull the pin out, as I said, this screw is smaller than RG6, so I cannot even screw a F (or RG6) connector to it.
It does look like a solder tab as Frosteh said, but I have no clue how to deal with the screw part of it. Looks like my best bet would be to take these two connectors out and replace them with a real RCA to F keystone connector. I am just glad that I am not the only one here who looks at this and scratches his head biggrin.gif
Edit: Another option I am thinking about is a big electronic store near by, Do It Yourself Electronics. I'll probably take it to them on the weekend and see if they can direct me to something.
SBI is offline
post #10 of 20 Old 11-22-2012, 09:46 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Call OSD support, and return it if it's not what you ordered.
Neurorad is offline
post #11 of 20 Old 11-22-2012, 10:09 PM
Colm's Avatar
Liked: 94
The connectors in question appear not to be RCA to F bulkhead connectors, but rather RCA to solder cup bulkhead connectors, and they are missing the required tabbed washer to make the second half of the connection.
FWIW there is no such thing as a RG6 connector. RG6 is a generic name for a wide variety of coaxial cable meeting certain basic specifications. It can be terminated with a variety of connectors including F-connectors, BNC connectors, RCA (phono) connectors, and others.
Colm is offline
post #12 of 20 Old 11-23-2012, 05:37 AM - Thread Starter
SBI
SBI's Avatar
Since I am not familiar with this solder cup bulkhead connector and the missing part, do you know if I can buy it anywhere? Can you point to a link where I can see what's missing?
SBI is offline
post #13 of 20 Old 11-23-2012, 08:19 AM
SAM64's Avatar
Liked: 78
Those are RCA connectors with solder cups.
SAM64 is offline
post #14 of 20 Old 11-23-2012, 08:40 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
If you must use this plate, you can replace those 2 connectors. Loosen the lock nuts behind the plate to remove them. You can buy replacement connectors online or from Radio Shack, or remove the connectors from another plate (Home Depot), and use them.
Neurorad is offline
post #15 of 20 Old 11-23-2012, 06:01 PM
Colm's Avatar
Liked: 94
Look here. The tab perpendicular to the jack is used to connect the shield of the coaxal cable. The solder cup is used to connect the center conductor.
You options are send it back and get the right thing or try to make what you have work. All you need to make it work is two F-type barrel connectors which are widely available, including at Radio Shack. You may have to drill out the mounting holes to fit.
Colm is offline
post #16 of 20 Old 11-24-2012, 05:57 AM - Thread Starter
SBI
SBI's Avatar
Thank you all. Got two normal RCA to F connectors, perfect fit to this plate. Not sure what OSD had in mind when they put the original useless in.
SBI is offline
post #17 of 20 Old 11-26-2012, 10:51 AM
SAM64's Avatar
Liked: 78
They're only useless for people who can't solder.
SAM64 is offline
post #18 of 20 Old 11-26-2012, 11:38 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Really? I'm pretty sure there are RG6 and RG59s. Check out this link......
RG6 vs RG59
The RG59s are a bit smaller so maybe the OP should be using RG59s F connectors..
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #19 of 20 Old 11-26-2012, 11:55 AM
SAM64's Avatar
Liked: 78
There are no photographs of 'F' connectors in this thread.
SAM64 is offline
post #20 of 20 Old 11-27-2012, 08:38 AM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
you have a solder tab connection, missing the ring for the shield connection, just as Colm and SAM64 have suggested.
order a pair of these and remove the connector from the keystone insert, then you will be good to connect your F connector equipped coax, leaving a conventional RCA to connect to your sub
underachiever extraordinaire
weaselfest is offline
