Surround Speakers: Rear Mounted Vs. Speaker Stands - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-27-2012, 12:57 PM - Thread Starter
skyjuice's Avatar
Hi All,
I'm about to pull the trigger on the NHT 5.1t Surround Package(http://www.nhthifi.com/Home-Theater-Absolute-5-1T-System?sc=12&category=3830).
I'm torn between the on-wall speakers vs. the bookshelves for the surround speakers.
From an acoustic perspective, is it better to use speaker stands each side of the sitting area or use wall mounted speakers that are placed on the back wall right behind the couch?
My room size is 13x13, but I can't mount the speakers on one side wall due to a window.
Appreciate any and all input.
skyjuice is offline
post #2 of 6 Old 11-28-2012, 04:30 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
In that size room I would guess that the seating is right up against the rear wall. If so, the best option would be to mount the surrounds in the corners, if possible, facing out on 45* angles.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 6 Old 11-28-2012, 07:58 AM - Thread Starter
skyjuice's Avatar
You are right. The couch is flush against the back wall. The challenge with mounting is that the right side of the room is three windows, making mounting a big challenge. So I have to choose between on-wall speakers on the back wall or speaker stands.
Thoughts?
Thanks for your input.
skyjuice is offline
post #4 of 6 Old 11-28-2012, 08:52 AM
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
Thoughts?
You could always get the mounts that hang from the ceiling and mount the speakers to the ceiling right in the corner of the room.
purbeast is offline
post #5 of 6 Old 11-28-2012, 08:54 AM - Thread Starter
skyjuice's Avatar
Interesting. It's sounds like I should go with the bookshelf speakers regardless as they can more adjusted a bit more easily.
skyjuice is offline
post #6 of 6 Old 11-28-2012, 09:12 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
The adjustment is in the mounts themselves. So either an on-wall or bookshelf speaker will work, just a matter of connecting them to the mount.
4DHD is offline
