LG BH4120s - AVS Forum | Home Theater Discussions And Reviews
Old 12-04-2012, 04:24 PM - Thread Starter
thepete1's Avatar
Hi Everyone
I bought a cheap HTIB on black friday for $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16882005116&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-NA-_-NA
I know it is not the greatest but for the money the sound is actually great.
What I want to do is connect the speakers to my Sony receiver as the receiver it came with does not have an optical input It only has an RCA L/R input which I understand will not give me true surround sound.
The problem is this: The subwoofer uses only regular speaker wire to connect as it does not have a bulit in amplifier. I know this will not allow me to connect to a receiver that only has a single RCA out but my receiver has 2 RCA outs for the sub.
The receiver is a STR-DE635
I found a picture of the back here
http://greencitizen.dreamhosters.com/ebay/BG1211082151/005.JPG
Is there anyway I can connect my sub to this?
If not I have a Bose PC speaker system that has a powered sub. Can I connect that to the receiver? It also harnesses the controls for the bose set but I only want to use the sub if needed.
Thnaks for the help!
thepete1 is offline
Old 12-04-2012, 09:38 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 779
In general, the "cheapest" part of most HTiB systems are the speakers. And that's all you'd be using out of the pack...
No.
The sub is unpowered (it's just a speaker). "RCA outputs" are line-level, un-amplified outputs from the receiver. As the market moved to self-contained "powered" subwoofers, AV receivers responded with a line-level output, leaving amplification to the sub itself.
Hard to say, but knowing Bose, probably not.
Sorry.
Jeff
jautor is online now
