Can I mount multiple TVs to a single one-piece mount? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-07-2012, 07:11 AM - Thread Starter
cknollen's Avatar
Good morning,
I have a dilemma. I want to wall mount 3 TVs to a single wall in my basement next to each other. It will be my own sports media center (a.k.a. 5 hr energy dome). The main (center) TV is a 60" Panasonic Plasma. There will be a 42" Panasonic Plasma on each side. My basement was previously finished with gypsum board and wall paneling. The studs on the wall I need to mount to are spaced a little inconsistently and I am unsure if I will be able to place a wall mount on the right side without adding additional stud material. Is there a long single piece (universal) wall mount bracket that I could install along the entire wall, and then attach the TVs to this bracket. That way I can take advantage of all of the studs strength along that wall to help support the weight of the three TVs. I can't believe I am the only person that has been looking for something like this... but maybe I am. smile.gif
Thanks for your help.
cknollen is offline
post #2 of 2 Old 12-07-2012, 07:27 AM
jautor's Avatar
Quoted: 1252 Post(s)
Liked: 803
You'll need to search the commercial mounts for one. Try searching for "digital signage" and "video wall" mounts.
I didn't see anything on the Chief site, which isn't a good sign...
jautor is online now
