What speaker wire should I use?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 12-10-2012, 02:37 PM - Thread Starter
studioholic55's Avatar
I'm piecing together a 7.2 system and I'm just wondering what speaker cable you guys recommend and/or use for your systems. I'm probably going to buy the BIC Acoustech PL-66s for sides and the FH-65Bs for rears. If anyone has any thoughts on other speaker options under or around $200/pair please chime in.
Thanks for your help, Jack
studioholic55 is offline
post #2 of 26 Old 12-10-2012, 03:36 PM
mn_hokie's Avatar
mn_hokie is offline
post #3 of 26 Old 12-10-2012, 03:49 PM - Thread Starter
Thanks, I checked it out and the reviews back it up. I think I'm gonna pull the trigger.
post #4 of 26 Old 12-10-2012, 03:52 PM
mn_hokie's Avatar
As long as you're buying the proper gauge and something well insulated, there's no need to spend big money on some of the pricer (cough... Monster) brands.
mn_hokie is offline
post #5 of 26 Old 12-10-2012, 07:26 PM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
+1 Monoprice. There are many distributors online. Check prices at your local electric supply store.
I use 16 gauge.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 26 Old 12-11-2012, 07:41 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
Monoprice or Ace hardware. There is absolutely nothing wrong with electrical cord in 16 Ga or 14 Ga for speakers.
jayn_j is offline
post #7 of 26 Old 12-12-2012, 04:25 AM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
Don't run 'electrical cord' aka zip cord in the wall.
Neurorad is offline
post #8 of 26 Old 12-12-2012, 06:47 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
Agreed. Don't use any cable that isn't rated for in-wall use.
jayn_j is offline
post #9 of 26 Old 12-12-2012, 02:38 PM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
Unless, of course, it's not in-wall.
Neurorad is offline
post #10 of 26 Old 12-13-2012, 06:58 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
jayn_j is offline
post #11 of 26 Old 12-13-2012, 09:38 AM
purbeast's Avatar
Liked: 27
Not to thread jack too much, but when I go to do all of my wiring, I am not going to have an outlet on the ceiling for my projector.
Is there any specific type of extension cord to look for when looking to make that plug longer so that I can actually run it somewhere near an outlet?
Or is something like that just a really bad idea?
For speaker wire, if I'm going to be running wires like 30-40 feet in wall, what gauge wire should I be looking at?
purbeast is offline
post #12 of 26 Old 12-13-2012, 09:46 AM
mn_hokie's Avatar
14-16 Gauge will be fine for those runs. No need to spend the extra money on thicker 12 gauge.
How do you plan to get the power cable from the projector to the wall? will it just gone straight down in the back of the room or are you talking about running the cable along a soffit or something? While not ideal, a standard extension cord should do. You can also put a surge protector at the end of the cord to help reduce risks.
mn_hokie is offline
post #13 of 26 Old 12-13-2012, 09:49 AM
purbeast's Avatar
Liked: 27
Well I had planned on running it behind ceiling where there is a beam that runs the length of my ceiling in the direction I want. My projector is mounted right near this beam.
So I planned to cut a hole in the wall that is around the beam, then run it behind the wall next to the beam, into a wall on the side of the room then out the wall.
Is all that feasable by simply getting an extension cable and running it inside of the ceiling and out of the wall, or is that a bad idea?
It will eventually be plugged into a surge protector before going to the actual wall outlet.
purbeast is offline
post #14 of 26 Old 12-13-2012, 09:50 AM
mn_hokie's Avatar
It's definately not up to code to run extension cords behind walls. If you're going to cut into the walls, I would highly recommend having an electrician come out to put an outlet in for you.
mn_hokie is offline
post #15 of 26 Old 12-13-2012, 11:19 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
Agreed. If you are going to have to cut holes and fish wire, you might as well cut a square hole for an old work box and fish 14/2 down to an exisitng outlet box and tie it in there. Neater, cleaner and to code.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #16 of 26 Old 12-13-2012, 11:35 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
Having the electrician add an outlet is best. Do NOT run an extension cord in the wall. If you have a fire, this sort of thing will void your insurance. If you don't want to hire the electrician, amazon and monoprice both sell something called a powerbridge. It is basically an extension cord with wall plates on each end. It uses standard romex wire, so it is in-wall rated, and does not require an electrician or any special training. They have become popular because of wall mounted TVs where the owner doesn't want visible wires hanging down, but they work great with projectors as well.
As an added bonus, the power bridge solution also allows you to plug into the UPS/surge protector.
jayn_j is offline
post #17 of 26 Old 12-13-2012, 11:47 AM
purbeast's Avatar
Liked: 27
Okay cool thanks for the information. My friend who is an electrician is going to help me fish wire so I will mention this to him as well. He's coming over tomorrow so I will run some ideas past him and see what he thinks is best for the situation.
I just searched on amazon for that power bridge item and that does look like a pretty good solution.
I'll see what he thinks is best though since I do only need 1 outlet near the projector.
As far as speaker wire goes, for the 30-40 feet or so I'd run it, would the gauge difference between 16 and 14 really matter?
purbeast is offline
post #18 of 26 Old 12-13-2012, 01:00 PM
mn_hokie's Avatar
mn_hokie is offline
post #19 of 26 Old 12-13-2012, 01:09 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
^^^^^^^^Yup funny stuff. Oh, and if you are concerned about your garbage man turning you in, do what I do .Find out what beer he likes and buy him a case or two and he will start looking more closely at your neighbors. Works like a charm!
RTROSE
RTROSE is offline
post #20 of 26 Old 12-13-2012, 01:09 PM
macfan's Avatar
Quoted: 23 Post(s)
Liked: 43
I assume that comment was aimed at me. Just to be on record I do not drink.
macfan is offline
post #21 of 26 Old 12-13-2012, 01:12 PM
mn_hokie's Avatar
You would have been better off admitting that you drink heavily. Recommending that someone gets a DIY book to run electrical, even if they are completely new to it, is only the first of the nonsense recommendations I've seen here. And suggesting that people cut corners and not follow code simply because it's a means for the city to make money? Without codes, you can pretty much throw safety concerns out the window with any new construction project.
Please let us know if your house ever goes up for sale so that the members here can avoid it like the plague. I can only begin to imagine how many hidden secrets it holds.
mn_hokie is offline
post #22 of 26 Old 12-13-2012, 01:30 PM
macfan's Avatar
Quoted: 23 Post(s)
Liked: 43
We are of two completely different mindsets and is exactly why there is both chocolate and vanilla, as well as Democrats and Republicans. BTW, my dad before he passed away, was a card carrying Journeyman Electrician. I used to work with him when he needed an extra hand. I guarantee everything in my home is up to code and will pass inspection. And I stand by my comment that anyone with a DIY book and a little common sense can do electrical work.
macfan is offline
post #23 of 26 Old 12-13-2012, 01:36 PM
mn_hokie's Avatar
Yes - crazy, and not crazy.
mn_hokie is offline
post #24 of 26 Old 12-13-2012, 01:45 PM
macfan's Avatar
Quoted: 23 Post(s)
Liked: 43
LOL, opinions vary on that. I have better things to do than trade insults with you. Have a good day.
Oh, BTW, I am a retired teacher with 31 years experience and 3 earned college degrees. Apparently some people don't think I am all that crazy.
hmmmm, hokie, laughs, knows what that means in slang terms
macfan is offline
post #25 of 26 Old 12-13-2012, 01:50 PM
mn_hokie's Avatar
I usually sit on the sidelines here, but when a post is made that could lead to safety issues, someone has to say something. Teach all you want - just stay away from my panel box.
mn_hokie is offline
post #26 of 26 Old 12-14-2012, 04:43 PM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
My dad never touched a hammer or screwdriver. He called someone to change light bulbs. I had to start from scratch, with my electrical knowledge..
With no experience with electrical, one has to start somewhere. For some, books are a solid start. I suggest more than one title, and multiple read throughs.
I've learned a ton from reading about electrical, though I'm still super careful, and paranoid.
macfan likes this.
Neurorad is offline
