Theater Setup Feedback and Surround Dipole vs Bipole Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-15-2012, 12:20 PM - Thread Starter
BarryNS's Avatar
Looking for input from folks on the theater setup I have.
I drew up this quick floorplan with powerpoint. Unfortunately, I don't have much to work with for any different setup/layout than what I have due to the way the room is shaped and the available space with the adjacent dining area strictly "off limits". The primary seating position is definitely the sofa.
My surrounds can be set to either dipole or bipole, I am wondering which is the best to use given their placement and the room layout? The left surround really can't produce much for reflections off the left wall as it is almost touching the window covering/drape for the corner window, and the right surround meanwhile has "open space" next to it since it is mounted right at the edge of the back wall where it opens up to a hallway.
I'm also wondering if the sub would be better located somewhere else?
BarryNS is offline
