Considering speakers/ placement for my room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-21-2012, 01:40 PM - Thread Starter
djkest's Avatar
Quoted: 35 Post(s)
Liked: 44
Hi. I'm going to start working on my theater room soon and I'm trying to figure out what I should do for the rear and rear surround speakers. I am not currently concerned about matching my front soundstage to the rear speakers.
Here's a detailed drawing of dimensions, room treatments, and proposed speaker placement.
At first I was wanting to do speakers mounted on the wall or very close to the wall. Then I was thinking about in-wall or in-ceiling speakers for the rear speakers. Now I'm just now sure. I know that speakers generally don't perform as well when on or very close to a boundary unless designed for that way. The surround speakers location and distance look fine, but the rear speakers seem like they would be incredibly close to the listening positions.
Any suggestions?
For in-walls I was looking at the Emotiva speakers (although I haven't heard them).
For surround speakers I am considering the HSU-HB1 MK2 (having heard them and liking the specs); that's about my price limit $150/each.
I have seen a lot of different ways people do their rear speakers and I'd really like something mounted fairly high-up on the wall (I have aa small kid) and maybe angled down and /or inverted.
djkest is offline
post #2 of 4 Old 12-22-2012, 12:43 AM
Roger Dressler's Avatar
Quoted: 1857 Post(s)
Liked: 986
I'm assuming the rear speakers are above the window. If so, inwalls can work. Aim-able tweeters will be useful.
Could consider moving the sofa another foot away from the back wall (and the side surrounds, too). That will get some needed distance from the rear speakers. It will also help the front L/R soundstage and the TV will look a little bigger.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is online now
post #3 of 4 Old 12-24-2012, 06:59 AM - Thread Starter
djkest's Avatar
Quoted: 35 Post(s)
Liked: 44
Yeah, I can move the couch a little bit further away from the wall, but not too much. Unfortunately we need a good space since it's a "walk-through" room. Above the window, probably. I'll have to look and see how much room is above the window, can't be more than 18" though.
Could also ceiling-mount normal speakers as well.
djkest is offline
post #4 of 4 Old 01-11-2013, 12:41 PM - Thread Starter
djkest's Avatar
Quoted: 35 Post(s)
Liked: 44
Bump. Just wanted to see if anyone had any ideas or suggestions for this layout. This is a "construction bluprint" for what we are going to do so the door/wall and the opening/wall are able to be changed, at least a little. Worried about noise from the furnace, but I'm afraid there isn't too much I can do about that since it's right next to the room and will require some louvered doors for access.
djkest is offline
