Advise on how to cover in wall speaker wire holes - AVS Forum | Home Theater Discussions And Reviews
Old 12-21-2012, 06:10 PM - Thread Starter
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
Any ideas what I can use to cover these holes? I don't want a normal plate. Is there anything I can do other than just using sparkle? Thanks
Brian Fineberg is offline
Old 12-21-2012, 07:05 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Often, the speaker mount is hollow, and covers the penetration.
You still might be able to do a bushing.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 12-21-2012, 07:06 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
My half gang wall plate idea is gaining traction.
Neurorad is offline
Old 12-21-2012, 10:26 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
http://cocoontech.com/forums/topic/13053-12-14-gang-brackets-wall-plates/
Grommet is your best bet, at this point.
Neurorad is offline
Old 12-22-2012, 06:21 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You might be able to use a console mount plate, with connectors. Try a Google image search for "Neutrik D Series" to get an idea of what I mean.
Neurorad is offline
Old 12-24-2012, 11:29 AM - Thread Starter
Liked: 3514
Can't find theses anywhere. Any other ideas?
Old 12-24-2012, 01:12 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Search Arlington + bushing + drywall.
Neurorad is offline
Old 12-24-2012, 01:27 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
If you're creative you can make your own.
If you're rich, you can pay someone to do it. Contact some companies that make custom wallpates. Or, someone who does 3D printing.
Neurorad is offline
Old 12-24-2012, 03:32 PM
mbarland's Avatar
Quoted: 12 Post(s)
I like using something like these: http://www.amazon.com/Leviton-88013-Telephone-Wallplate-Thermoset/dp/B00004YUJU/ref=sr_1_2?ie=UTF8&qid=1356388179&sr=8-2&keywords=wall+plate+hole
Give a nice finished look and easily pass the WAF test. I put some of those screw-in sheetrock anchors, which I then thread the finished wall plate cover screws into.
They make it them with different sized holes, for larger or smaller diameter cables.
mbarland is offline
Old 12-24-2012, 08:03 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You could buy a blank single gang plate, cut it up, and make it smaller, gluing together the pieces. You could sand and paint it, too, though some plastics are harder to paint than others.
Neurorad is offline
