need help with speaker placement for home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-23-2012, 07:41 AM - Thread Starter
sdepace's Avatar
I recently put up a projector and screen in my family room. The screen covers my speakers and I'm no longer happy with the sound. I need to move the speakers and possibly replace my center speaker with a new one. The speakers I currently own are sonance virtuoso 832D. Does anyone have any advice on 1) should I move my left and rights to position 1 or 2? 2) should I move the center speaker to the ceiling, buy a new directional ceiling speaker or build a mount for my 832d at an angle and try to place it above the screen? Thanks
sdepace is offline
post #2 of 5 Old 12-24-2012, 07:03 AM
Scout's staff's Avatar
Is the screen acoustically transparent (AT)?
Scout's staff is offline
post #3 of 5 Old 12-24-2012, 10:07 AM - Thread Starter
sdepace's Avatar
No. it's not. I wasn't aware that was an option. Can you suggest a 100" wide screen that would fit a budget of under $600?
sdepace is offline
post #4 of 5 Old 12-24-2012, 10:23 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 83
Unfortunately, I think you'll have difficulty finding an AT screen - especially a drop-down AT screen - in that price range. Your best bet will most likely be Seymour AV - a lot of people here use that material.
The Seymour AV 100" wide (16:9) drop down screen is $1,765 per their website. You may wish to call them to see if retrofitting the AT material into your current drop-down frame is a possibility.
http://www.seymourav.com/
I believe Jamestown also offers inexpensive screen options (although I don't know anything about the company or whether they offer an AT option): http://www.jamestownhometheaterscreen.com/.
AirBenji is offline
post #5 of 5 Old 12-24-2012, 12:49 PM
Sonyad's Avatar
Quoted: 190 Post(s)
Liked: 111
Check Amazon. I saw options by Elite in the $300 range.
Sonyad is offline
