Brian's Bar Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #91 of 199 Old 07-17-2013, 07:29 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
Oh, man! How did you strip it?
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #92 of 199 Old 07-17-2013, 04:38 PM - Thread Starter
hltr's Avatar
Liked: 26
Here we go again! Dye reapplied...
____________________
Brian's Bar Build
hltr is offline
post #93 of 199 Old 07-17-2013, 04:44 PM - Thread Starter
hltr's Avatar
Liked: 26
Fast and easy to do since the varnish had not fully cured.
http://www.homedepot.com/p/Citristrip-1-2-gal-Safer-Paint-and-Varnish-Stripping-Gel-HCG73803T/100141801
Brian's Bar Build
hltr is offline
post #94 of 199 Old 07-18-2013, 05:40 AM - Thread Starter
hltr's Avatar
Liked: 26
First coat of Waterlox...
AppleMark
Brian's Bar Build
hltr is offline
post #95 of 199 Old 07-18-2013, 06:34 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
NICE job! Looks GREAT!
I'll have to check that stuff out if I ever need it.
hltr likes this.
Tom Logan
post #96 of 199 Old 07-18-2013, 06:42 AM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
Works great on flat surfaces is a total bitch on nooks and crannies. I tried it on my railing spindles, the end result for me was not good. frown.gif
Play like a Raven
design1stcode2nd is offline
post #97 of 199 Old 07-18-2013, 07:38 AM - Thread Starter
hltr's Avatar
Liked: 26
I also used it on my 1939 jukebox. I found that you really have to be liberal with it...continue to wipe down and reapply until you truly get to the wood. But on something that detailed and very vertical I can see that being a treat. eek.gif
Brian's Bar Build
hltr is offline
post #98 of 199 Old 07-18-2013, 10:40 AM - Thread Starter
hltr's Avatar
Liked: 26
Pendant lights from Home Depot (Westinghouse). Philips Hue bulb in each....
AppleMark
Brian's Bar Build
hltr is offline
post #99 of 199 Old 07-18-2013, 05:43 PM - Thread Starter
hltr's Avatar
Liked: 26
Ever been at a bar and your phone is running out of power? Well, that's not going to be an issue here!
Brian's Bar Build
hltr is offline
post #100 of 199 Old 07-19-2013, 03:20 AM - Thread Starter
hltr's Avatar
Liked: 26
Second coat of Waterlox...I think we're good! Don't worry...those aren't marks in the finish, that's a reflection of the ceiling :-)
AppleMark
AnnapolisSony likes this.
Brian's Bar Build
hltr is offline
post #101 of 199 Old 07-19-2013, 06:05 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
FAB-U-LOUS!
hltr likes this.
Tom Logan
post #102 of 199 Old 07-19-2013, 08:35 AM
AnnapolisSony's Avatar
Quoted: 93 Post(s)
Liked: 138
Fantastic work. I'm sure this is another case of "pictures just don't do it justice"...
hltr likes this.
Displays: Epson 5030UB | 100-inch Elite Sable Fixed Mount | Samsung UN46F5500 LED TV
Sources: Yamaha RX-A1010 | Emotiva XPA-3 | OPPO BDP-103 | Panamax M5300 | Pro-ject Carbon Debut Turntable | Sonos Connect | Apple TV
Speakers: Polk 265-RT (L/R) | Polk 255C-RT (C) | Polk 65RT (L/R SUR) | Polk RC80i (L/R REAR SUR) | Subwoofers: PSA XV-15se X 2
Controls:Wall-mounted iPad AVS Forum Thread: 904WMC Media Room Thread
AnnapolisSony is offline
post #103 of 199 Old 07-19-2013, 09:06 AM - Thread Starter
hltr's Avatar
Liked: 26
Thanks. Tons of finish work to do, but I'm pleased with the way the major pieces have worked out.
Brian's Bar Build
hltr is offline
post #104 of 199 Old 07-19-2013, 09:13 AM - Thread Starter
hltr's Avatar
Liked: 26
I am very pleased with the way this Waterlox is settling in. I'll do one more coat tomorrow morning before I do a very light sand with 325, then another coat or two.
AppleMark
Brian's Bar Build
hltr is offline
post #105 of 199 Old 07-19-2013, 09:27 AM - Thread Starter
hltr's Avatar
Liked: 26
Brian's Bar Build
hltr is offline
post #106 of 199 Old 07-19-2013, 09:59 AM
Quoted: 31 Post(s)
Liked: 44
I am very please with the way this Waterlox is settling in. I'll do one more coat tomorrow morning before I do a very light sand with 325, then another coat or two.
AppleMark
Really bringing out the nice grain on the mahogany.
Play like a Raven
post #107 of 199 Old 07-19-2013, 12:45 PM - Thread Starter
hltr's Avatar
Liked: 26
Agree. I wasn't sure if the rail (which is African mahogany) and bar top (genuine) would match, but it's fine. The grain is certainly different, but I think they complement each other well.
Brian's Bar Build
hltr is offline
post #108 of 199 Old 07-20-2013, 09:00 AM - Thread Starter
hltr's Avatar
Liked: 26
Third coat of Waterlox
Brian's Bar Build
hltr is offline
post #109 of 199 Old 07-22-2013, 02:50 AM - Thread Starter
hltr's Avatar
Liked: 26
Just applied the fifth coat this morning. I was a bit disappointed after coat #4 because the foam brush had missed a few spots (probably too much pressure or uneven pressure. The stuff is so clear that I didn't catch this, and so I had a couple of valleys that didn't fill in as the product flowed out. No big deal, but since I'm nearing the end, I want these last coats to go perfectly.
I went back to the Waterlox site and was reading the application instructions. Turns out I had missed a very important step, and I'd imagine many others have as well, so I'm posting it here.
As you apply a coat, the first strokes are supposed to be across the grain, not with it. Then, without redipping the brush, you go with the grain. This is brilliant because it takes care of any missed spots and levels out the coat perfectly. Doing any woodworking "across the grain" is completely counter-intuitive to a woodworker, but for this it works.
Fifth coat is sweet. At this point I plan to apply a few coats wiped on.
Brian's Bar Build
hltr is offline
post #110 of 199 Old 07-23-2013, 09:50 AM
Quoted: 31 Post(s)
Liked: 44
I wouldn't have looked at it either, always been told to work with the wood's grain.
Play like a Raven
post #111 of 199 Old 07-23-2013, 02:58 PM - Thread Starter
hltr's Avatar
Liked: 26
I made an account at sawmillcreek which is where a lot of experienced woodworkers hang out. I found that in fact this type of application is standard, believe it or not. Just want to be sure that you don't wait very long to get it done so that the varnish isn't setting up.
Brian's Bar Build
hltr is offline
post #112 of 199 Old 07-24-2013, 06:20 AM - Thread Starter
hltr's Avatar
Liked: 26
Have been learning a lot about varnish. I'm now doing "wiping coats" where you use blue "shop towels" and again it is so counterintuitive but it works amazingly well.
1. Fold shop towel in fourths
2. Soak in Waterlox (keep in mind that the original sealer/finish is already thinned, if you are using something else you may have to thing with mineral spirits)
3. Wipe on, using circular motion as if cleaning off a table after dinner
4. Unfold/refold so that the inner cloth is used (in case any contaminants are on the first side used.
5. Lightly drag with the grain, overlapping strokes, to even out the varnish
This process is finally fun...the coats dry very quickly because they are so thin (about 45 minutes). Three coats in a day just about equal one brushed-on coat.
AppleMark
Brian's Bar Build
hltr is offline
post #113 of 199 Old 07-25-2013, 09:08 AM - Thread Starter
hltr's Avatar
Liked: 26
Valspar's Ventian Plaster on back wall..
Brian's Bar Build
hltr is offline
post #114 of 199 Old 07-26-2013, 03:37 PM - Thread Starter
hltr's Avatar
Liked: 26
Butcher block stained...
Brian's Bar Build
hltr is offline
post #115 of 199 Old 07-28-2013, 05:37 PM - Thread Starter
hltr's Avatar
Liked: 26
Sign mock up. "Clem's Place" was my grandfather's tavern in Chicago. My Dad's home bar is Clem's Place II, mine will be III.
Once I'm sure, I'm going to print to glass at http://fractureme.com
Brian's Bar Build
hltr is offline
post #116 of 199 Old 07-29-2013, 07:03 AM - Thread Starter
hltr's Avatar
Liked: 26
Bead board removal and drywall repair. Oh, and the ugly red post is now wrapped...
Brian's Bar Build
hltr is offline
post #117 of 199 Old 07-29-2013, 04:00 PM - Thread Starter
hltr's Avatar
Liked: 26
Work top varnished...
Brian's Bar Build
hltr is offline
post #118 of 199 Old 07-30-2013, 05:53 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
SCHWEEET!
hltr likes this.
Tom Logan
post #119 of 199 Old 08-02-2013, 01:45 PM - Thread Starter
hltr's Avatar
Liked: 26
Modern Masters (Benjamin Moore) synthetic Venetian Plaster. Decided to go with a lighter gold. Reacts very nicely to the different colors that the Hue bulbs generate.
Still have to sand it to a gloss...
Brian's Bar Build
hltr is offline
post #120 of 199 Old 08-03-2013, 12:26 PM - Thread Starter
hltr's Avatar
Liked: 26
Buffed out...
Brian's Bar Build
hltr is offline
