Brian's Bar Build - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #121 of 199 Old 08-05-2013, 10:17 AM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
When your friends come over for football they may never leave!
Next you'll need to build some Murphy beds for those that forget to bring a designated driver smile.gif
hltr likes this.
Play like a Raven
design1stcode2nd is offline
post #122 of 199 Old 08-08-2013, 07:38 AM - Thread Starter
hltr's Avatar
Liked: 25
Bar rail installed....
AppleMark
____________________
Brian's Bar Build
hltr is offline
post #123 of 199 Old 08-08-2013, 07:45 AM - Thread Starter
hltr's Avatar
Liked: 25
I've actually thought about a Murphy bed, but I think recliners will have to suffice, lol.
Brian's Bar Build
hltr is offline
post #124 of 199 Old 08-08-2013, 10:57 AM
Quoted: 31 Post(s)
Liked: 44
Maybe an inflatable mattress. I always thought I should have one of those just in case.
Play like a Raven
post #125 of 199 Old 08-08-2013, 11:31 AM - Thread Starter
hltr's Avatar
Liked: 25
THAT I have already :-)
Brian's Bar Build
hltr is offline
post #126 of 199 Old 08-09-2013, 07:12 PM - Thread Starter
hltr's Avatar
Liked: 25
Earlier in the thread I talked about the jukebox. It is not the exact one from my grandfather's tavern, but it is the exact model. Today I built it into the wall next to the TV.... the board above is one of the few remnants from the tavern.
Brian's Bar Build
hltr is offline
post #127 of 199 Old 08-14-2013, 12:09 PM - Thread Starter
hltr's Avatar
Liked: 25
Closet door....
AppleMark
AppleMark
Brian's Bar Build
hltr is offline
post #128 of 199 Old 08-28-2013, 07:35 PM - Thread Starter
hltr's Avatar
Liked: 25
First family party. Still lots of finish work to do, but things are looking ok.
Brian's Bar Build
hltr is offline
post #129 of 199 Old 08-29-2013, 09:07 AM
NickTheGreat's Avatar
Quoted: 384 Post(s)
Liked: 258
hltr likes this.
NickTheGreat is offline
post #130 of 199 Old 08-29-2013, 09:14 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
VERY NICE WORK! Looks AMAZING!
hltr likes this.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #131 of 199 Old 09-14-2013, 03:57 PM - Thread Starter
hltr's Avatar
Liked: 25
Pachinko macine rough in and beer faucets...
Brian's Bar Build
hltr is offline
post #132 of 199 Old 09-15-2013, 01:48 PM - Thread Starter
hltr's Avatar
Liked: 25
Moulding and stain....
Brian's Bar Build
hltr is offline
post #133 of 199 Old 10-09-2013, 04:00 PM - Thread Starter
hltr's Avatar
Liked: 25
Stained glass between joists.
Brian's Bar Build
hltr is offline
post #134 of 199 Old 10-09-2013, 04:03 PM - Thread Starter
hltr's Avatar
Liked: 25
Pachinko machine and shelves...
Brian's Bar Build
hltr is offline
post #135 of 199 Old 12-04-2013, 08:24 AM
pfmg's Avatar
NIce job! where did you get the under bar USB ports? great Idea.
pfmg is offline
post #136 of 199 Old 12-04-2013, 04:43 PM - Thread Starter
hltr's Avatar
Liked: 25
Thanks! I pieced it together like so:
First I used a paddle bit (5/8 if I recall) to drill the hole in front of each seat.
Then I covered with this...
Keyhole Escutcheon: http://www.signaturehardware.com/product19851
Then, from the backside, I inserted these into each hole:
http://www.monoprice.com/Product?c_id=103&cp_id=10314&cs_id=1031401&p_id=365&seq=1&format=2
I used a chisel to slice a little of the sides so it would fit snugly into the circular hole.
From there I just used USB cables (also from monoprice) to connect to the usb outlets that I installed on the bartender's side.
Brian's Bar Build
hltr is offline
post #137 of 199 Old 12-14-2013, 12:17 PM - Thread Starter
hltr's Avatar
Liked: 25
Holiday decorations
Brian's Bar Build
hltr is offline
post #138 of 199 Old 05-08-2014, 01:20 PM
Janaek's Avatar
Is your bar a total height of 42 inches?
On your idraw picture, you have a 36" plus the 6" foot rest. That is 42" not including the bartop!
Is that the way you built it? How thick is your countertop? If your total bar height is over the 42" (average height), including countertops, did that effect your bar stool size? Normal bar seat size is 30".
Thank you for you help... I am an amateur diy'er ; so any & all details are helpful.
Janaek is offline
post #139 of 199 Old 05-08-2014, 06:05 PM
Javatime's Avatar
Great lookin' build Brian.
Javatime is offline
post #140 of 199 Old 05-16-2014, 05:52 AM - Thread Starter
hltr's Avatar
Liked: 25
Thanks. My top is 44" and the tops of the seats are 31" including the padding. I'm very happy with this height, which I wanted to be comfortable for both sitting and standing at the bar.
Brian's Bar Build
hltr is offline
post #141 of 199 Old 05-19-2014, 03:16 PM
djearl81's Avatar
Quoted: 12 Post(s)
Your bar looks great. A lot of ideas to barrow if you don't mind.
I'm confused too.
djearl81 is offline
post #142 of 199 Old 06-14-2014, 06:18 AM - Thread Starter
hltr's Avatar
Liked: 25
Absolutely drearl that's why I shared. I researched lots of threads when I was planning.
Brian's Bar Build
hltr is offline
post #143 of 199 Old 06-14-2014, 06:49 AM - Thread Starter
hltr's Avatar
Liked: 25
Added a 50" Toshiba last week, very pleased with it. Perfect size for this space.
Brian's Bar Build
hltr is offline
post #144 of 199 Old 06-17-2014, 04:45 AM - Thread Starter
hltr's Avatar
Liked: 25
Vintage wall light found on eBay. Perfect with color scheme of the room, plus Miller Highlife was a staple in my grandfather's tavern.
Brian's Bar Build
hltr is offline
post #145 of 199 Old 06-17-2014, 09:46 AM
Quoted: 384 Post(s)
Liked: 258
I'm not especially a High Life fan, but that does look pretty nice in there
post #146 of 199 Old 06-17-2014, 10:56 AM
saldog78's Avatar
Quoted: 69 Post(s)
Liked: 73
Beautiful bar. Does the seam between the two pieces of butcher block bother you? We want to do a butcher block bar/counter in our basement, but we need it to be 18" x 9'8", and trying to get something that long is tough and expensive.
Which type of butcher block from Ikea did you buy, and what did you stain/varnish it with?
My Basement Build Thread - House sold... no more theater :(
Living Room: Vizio M70-D3, Yamaha RX-V773, PSA S3000i, Polk
Game Room: Samsung PN60E8000 Plasma, Onkyo TXSR600, PSA S3000i, Paradigm
saldog78 is offline
post #147 of 199 Old 06-17-2014, 12:03 PM - Thread Starter
hltr's Avatar
Liked: 25
Nick, I'm not either, but it's part of the story :-)
NickTheGreat likes this.
Brian's Bar Build
hltr is offline
post #148 of 199 Old 06-17-2014, 12:04 PM - Thread Starter
hltr's Avatar
Liked: 25
Since it is a work area for the bartender I don't mind it. I got the beech from Ikea and dyed it using General Finishes, then Waterlox on top.
Beech is soft, which again I don't mind as a work area, but oak may have been the better choice.
Brian's Bar Build
hltr is offline
post #149 of 199 Old 06-17-2014, 12:13 PM
CheYC's Avatar
Quoted: 35 Post(s)
Liked: 56
You just exponentially de-classed your bar . Seriously though, I'm jealous, looks awesome.
CheYC is offline
post #150 of 199 Old 06-17-2014, 12:32 PM - Thread Starter
hltr's Avatar
Liked: 25
I know, I know. But I mean, look at this pic from my grandfather's place in the late 40s. I had to pay homage.
Brian's Bar Build
hltr is offline
