Mounting Center Speaker On LCD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-28-2012, 12:14 PM - Thread Starter
umarsa's Avatar
Hi there,
I was wondering if there was anything out there in the market that allows me to mount my center speaker onto the actual LCD screen. I have attached pictures to help you understand my predicament.
This is the PC monitor I have at the moment and as you can see there are 4 standard mounting holes at the back.
(Phillips 221V)
This is the speaker I want to mount onto the LCD screen.
(Logitech Z906 center speaker)
So I'm looking for something like this as the end result..
(Excuse the bad paint work)
If anyone could help I would be really grateful.
umarsa is offline
post #2 of 6 Old 01-01-2013, 04:23 AM - Thread Starter
umarsa's Avatar
Anyone have any ideas at all?
umarsa is offline
post #3 of 6 Old 01-01-2013, 04:54 AM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
http://screendeck.tv/product-details/
check out the "ScreenDeck" a shelf that mounts to the VESA holes on the back of your monitor.
available for several screen sizes, although your PC monitor may be a bit small.
Good luck
underachiever extraordinaire
weaselfest is offline
post #4 of 6 Old 01-08-2013, 05:14 PM - Thread Starter
umarsa's Avatar
I can not seem to find this for sale in the UK and yeah I think it is way too big for my PC monitor..
Does anyone have any other suggestions?
umarsa is offline
post #5 of 6 Old 01-08-2013, 07:06 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You could make it/have it made
http://www.remotecentral.com/cgi-bin/forums/viewpost.cgi?1168230
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 6 Old 01-08-2013, 08:00 PM
bepperb's Avatar
It seems to me you want a rectangle of 1/8"/5mm aluminum, plywood, plastic... whatever with five holes drilled in it. Make a template out of cardboard and find someone handy with a jigsaw... and hopefully the same guy has a drill too.
I doubt a product exists that does exactly what you want because the distance from the vesa holes to the speaker mount hole would vary with display size, speaker size and whatever else. But it seems like an hourlong project at most.
bepperb is offline
